Old 11-22-2008, 06:29 PM
929nitro
Default Headlight command module
Hey everyone. I am posting here for my dad (it is his truck), he has a 2004 2500 and he has been having some problems with his headlights. Every now and then his drivers side headlight will go out, and usually stay out. Also when this happens, if he is towing a trailer, the trailer running lights will also go out. There doesn't seem to be any consistency to this happening, sometimes it will be out when he turns the lights on, other times it will just go out as he is driving down the road. Nothing seems to fix the problem either.
He has been told, by a dealership, that it is the headlight command module. I have two questions that I can hopefully get some help with. First question is, where is the location of the drivers side headlight command module? The second questions is, does anyone have any other ideas of what could be causing this problem? Thank you in advance for all of your help.
Old 11-23-2008, 05:12 AM
LYC79's Avatar
LYC79 LYC79 is offline
Trim Level: SXT CRD 2.0 / 2.8
Rep:426
Hi 929nitro ! Sorry I can't help you with your problem, but I guess someone else here will. Just wanted to say WELCOME and enjoy your stay! I hope you'll solve your problem. p.s. 929nitro... do you have a Nitro?
Old 11-24-2008, 11:11 AM
929nitro
I have a 21' Nitro bass boat.
Old 11-24-2008, 11:23 AM
LYC79's Avatar
Rep:426
Ah ok ... a bass boat ... sorry I was thinking about a Dodge Nitro !
Old 11-24-2008, 11:29 AM
Unbridled's Avatar
Unbridled Unbridled is offline
Vehicle: 2001 Dodge Ram 1500 4x4 w/318
Trim Level: Ext. cab Laramie SLT
Color: White w/ graphics
Rep:19
Unbridled is on a distinguished road
It sounds like a relay somewhere, but I have no idea where. Try unplugging the fuse that controls the trailer brake and see if that helps. It could be that the extra electrical load from the trailer is popping a relay. ????
Just a thought.
Welcome!
Old 12-27-2008, 10:13 AM
bluedodgeram's Avatar
bluedodgeram bluedodgeram is offline
Vehicle: 2011 Ram Sport 4X4 Crew Cab
Color: Deep water blue pearl
Rep:13
bluedodgeram is on a distinguished road
Not sure, it could be your daytime running lights module? But your headlights, when turned on, should bypass the module, but check to make sure.
Old 04-06-2010, 05:33 PM
locknload locknload is offline
locknload is on a distinguished road
Hello I got a 2000 dodge ram. The daytime running light's stay on when ignition is shut off. If anyone has any info on what it may be. Thank you.
Old 04-06-2010, 05:35 PM
Rep:1625
Welcome to the forum bud, we're glad to have you here. Go ahead and start a new thread in the "newbie checkin" section, we'd love to hear about you and your truck
How long do they stay on for?
Old 04-06-2010, 05:40 PM
Rep:1890
Time to stop blindly guessing, people! First of all, whoever used the phrase "headlight command module" doesn't have a clue what they're talking about. Chances are the FCM (front control module) is at fault. They have a fairly high failure rate and as you can see by the diagrams below, that it controls the lights that are malfunctioning.
Old 04-06-2010, 05:44 PM
Rep:1890
Most likely a bad DRL module.
