P0406 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 04-02-2010, 02:55 PM
matt miller's Avatar
matt miller matt miller is offline
Vehicle: 2004 DODGE RAM 5.7L HEMI
Color: SILVER
Rep:13
matt miller is on a distinguished road
Default P0406
Anyone had this show up when using the flashpaq 3815? how do you fix it?
I liked your car it looked good in my rear view mirror.
Old 04-02-2010, 03:06 PM
Resident Technician
Rep:1915
Replace your EGR valve. 99.9% of the time it's the culprit.
Old 04-02-2010, 03:09 PM
Rep:2946
i think i may have found the answer, someone else can tell you for sure
looks like the code that is coming up is the
•P0406 Exhaust Gas Recirculation Sensor A Circuit High
need to replace the EGR valve. P0406 is actually EGR position sensor high code. Which means the PCM recieved a egr position sensor signal greater than 4.89 volts.
The best way to get at the lower bolt after you remove the upper bolt and the two 8mm tube screws, pry the valve rearward. This allows you to get a socket on the lower bolt.
Old 04-02-2010, 03:17 PM
Resident Technician
Rep:1915
Ah hell! I just noticed you're right up the road from me.
Old 04-02-2010, 03:32 PM
Color: SILVER
Rep:13
yea you do dont you.i aint but like 30 min from you and i appreciate the help guys.
