Old 04-03-2010, 12:11 AM
les les is offline
les is on a distinguished road
Default les
ram 2500 5.9 magum looking for more hp the cheapest way possible.Its a 98 4 wheel drive with an automatic.I put on a KN cold air intake but no change.Any ideas?
98 ram 2500 5.9 cold air intake automatic 4wheel drive.
Old 04-03-2010, 12:18 AM
ScatPak07's Avatar
Rep:970
I would do a programmer and an exhaust, that will give you some good gains. It will make your CAI work a lot better
Old 04-03-2010, 12:20 AM
Rep:1625
I agree with Scat, those are the Big 3 when it comes to modding
Old 04-05-2010, 12:25 AM
les les is offline
what type of programmer do you recomend? What exhust mods do you recomend?
Old 04-05-2010, 12:49 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Superchips seems to be the best for our engine.
Old 04-05-2010, 01:08 AM
SUL7ENAZ's Avatar
SUL7ENAZ SUL7ENAZ is offline
Vehicle: 1999 Dodge Ram 1500 QuadCab
Color: blue
Rep:463
SUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of light
A complete ignition kit like this one from hughes engines is what i'd go with MSD 6A ignition module (6200)
Taylor 8mm Plug wires (74076)
MSD Coil (8228)
Accel Coil Adapter (140021AH)
Accel Distributor cap (120329)
Accel Rotor (130328)
These parts are often overlooked but in the magnum engines actually bring out some more power.
SUL73NAZ
Old 04-06-2010, 12:19 AM
les les is offline
I live at 6100ft. alt, would this have any bearing on what you recomend,and do you have any thoughts on exhaust?
Old 04-06-2010, 08:20 AM
Yondaime Yondaime is offline
Vehicle: 1997 Dodge Ram 1500 Sport 4x4
Color: Green
Rep:65
Yondaime will become famous soon enough
You can also put a under drive pulley on, headers, and throttle body spacer.
Old 04-08-2010, 07:46 AM
les les is offline
What is a safe guess to the differance in hp I could see with a programmer, with using just this mod alone,and with no other mods to the truck? Would there be any change in mileage?
Old 04-08-2010, 09:25 AM
Rep:1930
You can do different tunes with a programmer.
Superchips 3865
Key features: increases horsepower and torque, improves fuel economy, optimized driveability, diagnostic trouble code reading capability, internet updateable, easy installation without special tools.
Additional features: enhanced shift points & firmness, raise speed limiter, recalibrate speedometer for larger tire sizes, three available performance settings, latest calibrations and data acquisition is available at Flashpaq.com
