Old 04-04-2010, 11:56 AM
1liter 1liter is offline
Vehicle: 2003 Hemi quad cab 4x4
Trim Level: Sport SLT
1liter is on a distinguished road
Default 03 1500 hemi po300 code
I was towing a car the other night in a heavy rain going 75MPH or so and the truck started to shake realy bad I was thinking a Ujoint right off the bat but I was over a hour from home so I slowed down and shut off the OD and this raised the RPMs witch made it shake less witch was great till I had to get off the highway then the truck did not want to stay running I made it home by pumping the gas pedel at the red lights still no Check engine light till I pulled in my drive way itsays bank1 to rich and missfire #7. I pulled the plugs they look good gap and all I swaped the #7 coil out with one off of one of the other ones on my engine to see if it was the coil but now it says Po300 random misfire truck has a 125000 miles thanks to that can help.
Old 04-04-2010, 12:02 PM
RamTech RamTech is online now
Rep:1877
What were all the P codes that were originally stored? Did you clear the codes before starting the engine after swapping coils? I'd initially suspect a broken valve spring or bad injector.
Old 04-04-2010, 12:09 PM
it had a bank1 to rich and a misfire #7 code and yes I did clear codes after I swaped out the coils.
Old 04-04-2010, 12:14 PM
Rep:1877
You could try swapping injectors to rule that out. I'm leaning toward a broken valve spring since older Hemi's seem a bit prone to it and you've already checked the plugs and swapped coils.
Old 04-04-2010, 12:25 PM
but it is not telling me which #s ones to swap out I was thinking bad gas (I put gas in 30Mins before it started it Shake) so i put in a bottle of isoprople and ran it 20+ minutes with no change
Old 04-04-2010, 12:42 PM
Rep:1877
Start with #7 since you had a P0307 code first.
Old 04-04-2010, 01:05 PM
ok but why would i go from 307 code to the 300 code with only a coil swap? I am thinking I should try to put run sum of the gas out of it and put sum fresh super in it with sum more water remover before I start chasing my tail on this thing I will let you know thanks.
Old 04-04-2010, 06:24 PM
well filled the tank with super put 60Miles on it on the Hwy and it runs great if you floor it but under 2500rpm it skips when I got home I pluged in the scaner and it had 5 codes. (P0172 Bank 1 Rich) (Po202 Injector #2 Mal) (PO205 Injector#5 Mal Code twice) (Po207 Injector Mal #7 Code Twice) (PO300 Randum misfire) I will start with Fuel Presure Test what do you guy think?
Old 04-07-2010, 09:14 PM
nodody has any ideas??
Old 04-07-2010, 09:19 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Just bumping. How was the fuel pressure test?
