Old 04-05-2010, 08:12 AM
JR23 JR23 is offline
Vehicle: 2003 Quad Cab 2wd 5-speed
Color: Maroon
JR23 is on a distinguished road
Default High idle after CAI
So I tried to make a homemade CAI and after completion, I now have a very high idle (1700 rpm). I had some trouble w/ the IAT and located it to the 3" coupler @ the throttle body. If I broke the sensor, would this cause a high idle? Thanks for the help.
Old 04-05-2010, 09:41 AM
Rep:1909
No, it wouldn't but, it would set a code and illuminate the MIL.
Old 04-05-2010, 09:43 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Did the throttle get bumped when installing the CAI?
Old 04-05-2010, 12:20 PM
Color: Maroon
Yes, I might have bumped the throttle cable next to the throttle body. I drove it to work this morning (50 miles) and when I reached a stop it is reving from 1700-2500 up and down like its in a loop. I thought the computer might have re-set by now. i also tried un hooking the neg terminal on battery for 10 min to try and re-set the ECM.
Old 04-05-2010, 02:00 PM
Color: Maroon
Just disconnected the neg terminal, and will let sit for a couple of hours till I get off of work and see if the ECM will re-set. Any other suggestions?
Old 04-05-2010, 02:02 PM
Color: Maroon
Default High idle after CAI install
Any thoughts on why I have a 1700-2500 rev continuosly after installing a CAI?
Old 04-05-2010, 02:07 PM
Rep:1930
Why did you post this again? Your other thread was getting responses.
Old 04-05-2010, 06:02 PM
Color: Maroon
Sorry, I wanted to show my problem under a different group. How do I remove it?
Old 04-05-2010, 08:18 PM
Rep:1930
Its good, its been merged
Old 04-05-2010, 08:19 PM
Rep:1930
anything after taking the neg cable off?
If you did bump it, see if you can manually take the idle down?
