Old 04-05-2010, 08:53 PM
97ram 97ram is offline
Vehicle: 97, dodge, ram 1500 2wd ext
97ram is on a distinguished road
Default auto to standard
ok i have a 97 ext cab 1500 2 wheel drive. i wanna convert it to standard. did dodge make a 5 speed truck 318 that came standard? has anyone done this swap? any info will really help. is the clutch peddle set up hydralic or cable? i really want a 5speed. 6 speed would be awesome too but im on somewhat of a budget.
Old 04-15-2010, 01:22 AM
pbrahm pbrahm is offline
pbrahm is on a distinguished road
Dodge definately rolled some off the line with sticks, i own a 98 318 with a 5 speed, i to am lookin for 6-speed tranny due to the fact my factory tranny is busted
Old 04-16-2010, 05:44 PM
thanks for the info bro. i owned an 04 4.7 with a stick and it felt way peppier. so i want to go 5speed manuel. i also would like a 6speed but where would you get one that would bolt up?
Old 04-17-2010, 06:46 AM
Rep:4085
All I can say on this is yes, they did have 318's with a manual, my '81 started out that way, but we did the opposite conversion taking it to an automatic....definitely an undertaking going to a manual from an auto, but good luck with this and be sure to keep us posted on how it goes!
Old 04-17-2010, 09:47 AM
Roadrunner Ram's Avatar
Roadrunner Ram Roadrunner Ram is offline
Vehicle: 2011 Dodge Ram
Trim Level: R/T
Color: Mineral Gray
Rep:94
Roadrunner Ram will become famous soon enough
That sounds like A LOT of work with out much of a gain..
Full LED & HID, F&R Halo's, Debadged, Tinted, Black grille, Grillcraft Mesh insert, K&N CAI, Borla Duals, Nathan P3 Train horn, 70 Roadrunner dust trail graphics. Now I am broke...
Old 05-04-2010, 01:40 AM
johnson19's Avatar
johnson19 johnson19 is offline
Vehicle: 1997 Dodge Ram
johnson19 is on a distinguished road
Hey, I've got a truck identical to yours but mine is a regular cab, and I've also been kind of curious as to how well one of these swaps would go. It would be alot of work, but i've driven a couple 5.2's coupled to five speeds, and the 5 speed is definitely a huge improvement on the auto.
Old 05-31-2010, 09:29 PM
Workram Workram is offline
Workram is on a distinguished road
I had a V-6 5spd and swapped in a 5.2, ran into a little trouble finding a flywheel. What I ended up doing was prying the crank sensor ring off the v-6 flywheel then indexing and bolting a 5.2 flexplate to the backside of the flywheel using the torque convertor bolts. Once drilled tapped and bolted I simply cut the center out of the flexplate with a zipdisk on the die grinder. Bingo flywheel with 5.2 crank sensor ring, put about 50000km on it since then works great.
Old 06-24-2010, 05:45 PM
ncffp163 ncffp163 is offline
Vehicle: 1999 Dodge Ram 4X4
ncffp163 is on a distinguished road
I use to have a 96 1500 4X4 w/ 5.2 lt and a 5 speed manual...gawd I miss it!!
Old 06-26-2010, 08:08 PM
Chet Stedman Chet Stedman is offline
Vehicle: 99 Dodge Ram 1500 Quad CAB 4X4
Trim Level: SPORT 5-Speed
Chet Stedman is on a distinguished road
I have a 1999 Ram Sport 5.2 that was a stock 5 speed, I love it it has a HURST shifter and the clutch was replaced at about 100k and is still mint.
