Ram Eyes installed! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 04-06-2010, 01:03 PM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
Default Ram Eyes installed!
The other day I found a set of LEDs at PepBoys that were pretty cheap. You had your choice of color of white, red, blue, green, and yellow. I chose the red, and decided to do the Ram Eyes mod.
The hardest part was getting the tailgate emblem off. I ended up inserting my pocket knife behind the emblem and working it until I could get my fingers underneath. Once I got it started I was able to peel it off pretty easily.
I then spent the better part of an hour removing the left over tape from both the tailgate and the emblem. Once that was done I hit it with some Goo Gone until 99% of the goo was cleaned up. I then cleaned it with a soapy sponge to remove the slime factor left by the Goo Gone. I did the same with the emblem.
I apologize that I didn't take pics as I went along, which would've allowed me to do a proper write up. I didn't think about it until I was almost finished
Remove the T-27 screws in the tailgate, this will allow you to remove the bedliner section that goes over the tailgate (if you've got one of those) and the metal strip that goes across to cover up the hardware for the tailgate latch. Once this strip is remove you get pretty easy access to the inside part of the tailgate.
I drilled out the "eyes" on the emblem to slightly less than the 7/32" that the enclosed directions called for. I don't remember the exact drill bit size, but it was 2 bits smaller than the 7/32" (anyone good at math?). I started with a tiny bit, then slowly worked my way up to the size I needed. I wasn't taking any chances on cracking or breaking the emblem while drilling. I suspect most folks will have to check their LEDs to match the size.
Once the holes were drilled to the proper size I used Super Glue to secure the LEDs into the holes. I let the glue dry for awhile, then arranged the wires for the lights so that they'd "exit" through the hole in the tailgate. I then used 3M double sided tape (the stuff I used was about a 1/4" wide). I ran a strip around the entire outside edge of the emblem, and then added several small strip on the interior for extra hold.
Thread the wires through the hole in the tailgate. It's then just a matter of lining up the "pins" on the emblem with the holes on the tailgate and pressing firmly. I held the pressure on for several seconds to make sure that it stuck. I then clipped the wires so that both LEDs were wired together. I then used a heat shrink butt connector on both the positive (red) and the negative (black) wires. I tend to overkill when I'm wiring something up, so I cut off about 5 or 6 feet of wire when I made the connections to the LEDs. I then ran both of these wires through some small wire ploom that I had on hand. I then threaded this through the tailgate, and out of the bottom, letting the wires dangle toward the inside of the tailgate. There is plenty of room to do this.
Once underneath the truck I tie-wrapped the new ploom to another that was running to the trailer hitch connection (I think). I used this mainly because it was handy. I then tapped into the drivers' side license plate marker light (again because it was handy and worked off the headlight switch).
I used a meter to determine that the white/green wire was positive, and the black was negative. I tapped into these using quick splice connectors, and after testing to make sure everything worked I taped everything up nice and tight with several layers of electrical tape.
All total I'd say from start to finish it took me a little over 2 hrs, though I probably could've done it a bit quicker if I'd tried.
Here's a pic not lit.
And here it is lit up.
I just wish I could've gotten a decent pic without my cell phone reflecting in the Ram's head LOL
Exco
Bill
Old 04-06-2010, 01:11 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Looks great..............Love to see one in the dark.
Old 04-06-2010, 01:15 PM
Excoastie's Avatar
Color: Hydro Blue
Rep:1358
I'll try to get pics later. It's a lil after noon here, so it'll be awhile before I can get pics in the dark
I'm looking forward to seeing it as well....
Exco
Bill
Old 04-06-2010, 01:29 PM
Rep:1625
Looks good man, that's a sweet mod
Old 04-06-2010, 01:32 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Very cool mod, I think I need to add the huge emblem just so I can do it.
Old 04-06-2010, 05:31 PM
followme2dq's Avatar
followme2dq followme2dq is offline
Vehicle: 2006 Dodge Ram SRT10 rc
Trim Level: srt 10
Rep:53
followme2dq will become famous soon enough
very nice i like it
06 Ram SRT 10, Black! 13 2500 Big horn Crew Cab for towing and plowing!!!
Old 04-06-2010, 09:08 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Looks good! a nice simple mod!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 04-06-2010, 09:13 PM
ScatPak07's Avatar
Rep:970
Great Mod man!! Looks really cool! I think that is becoming a ram forum trade mark haha
Old 04-06-2010, 09:14 PM
BWG56's Avatar
BWG56 BWG56 is offline
Color: Mango Tango
Rep:19
BWG56 is on a distinguished road
nice job, I like
Old 04-06-2010, 09:44 PM
Rep:3347
looks clean... now we're just waiting for the night pics. That's a pretty cool pic with the 3-way split in the ram head though.
