Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 04-06-2010, 05:51 PM
dodgehemi dodgehemi is offline
Vehicle: 2004 Dodge Ram 1500
Trim Level: Quad Cab SLT 4X4
dodgehemi is on a distinguished road
Default Brake Pads
I have an 04 4 door 4x4 with 20 wheels.. I need to brake pads all the way around. What pads is everyone using and suggesting to use? Also, suggestions on new rotors would be great. Just bought the truck two weeks ago. Thanks guys.
Old 04-06-2010, 05:55 PM
Rep:1625
Welcome to the forum! Glad to have you here! I'd check out EBC brake pads and rotors. They seem to have some good reviews
Old 04-06-2010, 05:57 PM
droshemiram's Avatar
droshemiram droshemiram is offline
Vehicle: 03 dodge ram HEMI
Color: atlantic blue
Rep:89
droshemiram will become famous soon enough
Ceramics anything ceramics for me less noise and brake dust, Good stoping power.
Old 04-06-2010, 08:58 PM
ScatPak07's Avatar
Rep:970
I recomend getting EBC brake pads for your truck. They make a set called Greenstuff. The front they have premium Greenstuff pads which are 7000 and the rear is just the Greenstuff 6000. You can get the 6000 all around the 7000 is a premium pad.
EBC makes good rotors as well. They have drilled and slotted rotors for our trucks. Check them out, they are not that expensive as well
Old 04-06-2010, 09:55 PM
I push the skinny pedal
Rep:3277
I third the EBCs since I run them at all corners of both my trucks (ram 1500 & F-350 SD) and they wear nicely, are quiet, and stop both trucks quickly, even when the 350s hauling. Full pad/sport rotor set will run you about $550-600 which is about $100 more than stock replacements and gives you much better braking power. But if you don't want to spend that much, any ceramic pads will give you better bite, just make sure the rotors are true.
Kurtis
Old 04-06-2010, 10:36 PM
Awesome info so far. Where did everyone buy theres at? No problem spending that much. The back ones I need to replace in the next month and the fronts have about 30% left.
Old 04-06-2010, 10:57 PM
cuda71's Avatar
cuda71 cuda71 is offline
Vehicle: 2008 Cummins Dodge Ram 2500
Color: Electric Blue
Rep:27
cuda71 is on a distinguished road
I like that "they are not that expensive as well"
Old 04-07-2010, 12:10 AM
Rep:3277
Got mine off AutoAnything, and shipped to Canada, which takes longer but US shipping is normally within a business week. If you take the time to fill out your UserCP info we could have a reference to your year/model and get ya some more info if you have any questions/comments in the future.
Kurtis
