Old 04-07-2010, 01:16 AM
aolslayer's Avatar
aolslayer aolslayer is offline
Vehicle: 1998 Durango SLT 4x4 Green
Trim Level: custom
Color: Green
aolslayer is on a distinguished road
Send a message via Yahoo to aolslayer
Exclamation gas tank
ok i have a problem when it was cold this winter my fuel gauge stop working but as soon as it got warm it started working then cold gone again i talked to a dealership they had no clue other them me buying 300 dollar replacement float and pump and now it hot out it working but not all the time now. any ideas guy how to fix with out bustin my savings.
98 Durango SLT 4x4
Old 05-07-2010, 08:48 AM
RamTech RamTech is online now
Rep:1890
Sounds like a connection problem most likely. Check the plug on top of the tank for loose pin connections and corossion. Check the wiring running along the frame rail for damage. Use a DVOM to check continuity. If that's ok, load test the wiring with a light bulb.
Old 05-10-2010, 06:29 PM
aolslayer's Avatar
Trim Level: custom
Color: Green
thanks ill try that
98 Durango SLT 4x4
Old 07-05-2010, 10:43 PM
aolslayer's Avatar
Trim Level: custom
Color: Green
its started working some what today just cause it was really hot out and tonight when the temp froped outside not working again what the heck
98 Durango SLT 4x4
Old 07-05-2010, 10:53 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Did you check the connections and wiring as Randy recommended? What are the readings from the meter, and how much fuel was in the tank when you took the readings?
brad
Interested in one of my mods?
Old 07-06-2010, 09:10 PM
aolslayer's Avatar
Trim Level: custom
Color: Green
wires are good the meter show what should be right i think lol but it was 101 today here when the temp out side drops it stops working i dont understand it
98 Durango SLT 4x4
Old 07-07-2010, 01:18 AM
Dennyboy's Avatar
Dennyboy Dennyboy is offline
Vehicle: 1999 regular short box sport
Rep:140
Dennyboy will become famous soon enoughDennyboy will become famous soon enough
have you checked when its working and also not working? any change?
Dakota County Technical college
Auto Tech apprentice
cataclysmic perverter
If you don't stand behind our troops, PLEASE feel free to stand in front of them.
Old 09-16-2010, 06:04 PM
ikulla ikulla is offline
Vehicle: 1996 ram
Trim Level: sle laramie
Color: blue/sliver
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
ikulla is on a distinguished road
you can replace just the float assembly much cheaper then the sending unit, easy project, basic tool only, just make sure you run the truck as low as you dare before removing the tank , i forgot that step............
