Old 07-24-2010, 01:11 PM
hunTer06's Avatar
hunTer06 hunTer06 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Outdoorsman
Rep:60
hunTer06 is on a distinguished road
Send a message via MSN to hunTer06
Default NEED HELP with tranny temp guage
Recently purchased a transmission temp guage for my 318 ram. The kit came with 2 fittings for the temp sending unit, but the instructions say something about drilling into the pan? Im not doing anything like that, and Ive heard of people putting the sending unit into a transmission line. Has anyone done this on a 2nd generation ram? Any help will be appreciated!!
I see these transmission temp guage sending unit "manifolds" on summits website. Do I need something like this?
http://www.summitracing.com/parts/ATM-2286/
Old 07-24-2010, 01:12 PM
Rep:1915
Since you don't want to drill into your pan, that manifold would be the best way to go.
Old 07-24-2010, 01:15 PM
hunTer06's Avatar
Rep:60
and that manifold just goes into the line?
Old 07-24-2010, 01:21 PM
Rep:1915
Right. Split the metal line and install the manifold with the supplied compression fittings and then screw in the temp probe. You just need to keep in mind that one line will be hotter than the other. Personally, I prefer the probe to be in the transmission itself.
Old 07-24-2010, 01:25 PM
hunTer06's Avatar
Rep:60
I figure as long as its in the line GOING to the radiator it should be OK. Thanks for your help, it's just something i need to think about. Ive had this guage for a while and it just needs installed!
Old 07-24-2010, 02:00 PM
Theres something else you should consider . Theres a check valve in line to prevent drain back . My rebuilder said to remove it . It causes more problems than what it's worth . You will just need to remember that when you first start it up , not to throw it in gear and give it hell for a couple of seconds until the fluid gets circulating through out the system . The check valve is notorious for getting stuck and will cause transmission overheating conditions . It is up by the lower radiator hose .
Old 07-31-2010, 03:54 PM
mAs mAs is offline
Vehicle: 1994 Dodge Ram 1500 2WD
Trim Level: Laramie SLT
Color: Jet Black
Rep:36
mAs is on a distinguished road
Can you thread it into one of the pressure test ports? That is how I have always done it to my GM trannys. I got 297,000kms on my 91 Buick LeSabre transmission never been rebuilt and no issues other than 2-1 downshift klunk they are famous for in those years.
Old 08-09-2010, 09:29 AM
kicknjeep kicknjeep is offline
Vehicle: 1995 Dodge Ram 1500
Rep:26
kicknjeep is on a distinguished road
was thinking same as mAs on this one, correct me if I'm wrong but couldn't you use one of the ports right above the servo?.
Old 08-09-2010, 09:33 PM
hunTer06's Avatar
Rep:60
Just ordered the piece from summit. Looks like it will make it easy. I will let you all know how it goes when I get it done!!
Old 08-09-2010, 10:35 PM
Don't forget the pics .
