Old 04-07-2010, 10:17 AM
mike223 mike223 is offline
Vehicle: 2003 Ram 1500
Trim Level: 4x4 quad Cab
Color: silver
mike223 is on a distinguished road
Question Wiring schematic for trailer lights
Hey guys. Anyone know where to get and/or download a wiring diagram for the trailer light package. I do not have left brake or left signal working. I have a 2003 Ram 1500 Quad cab 4x4.
thanks guys
Mike
Old 04-07-2010, 11:18 AM
Rep:1625
Remerson is the man for uploading schematics. Once he sees this thread, hopefully he'll help you out
Old 04-07-2010, 11:28 AM
Rep:1845
Old 04-07-2010, 01:09 PM
Color: silver
Thanks guys. Hopefully will have a bit of time this weekend to take a look at it.
Old 06-23-2010, 11:46 PM
Dazed and Confused Dazed and Confused is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: 4x4 quad cab Laramie
Dazed and Confused is on a distinguished road
Default How did it go?
thanks guys
Mike
Hey Mike did you ever come up with the solution? I am having the same problem with the same truck. I think it might be the relay but not sure which one it is. Any advice would be appreciated.
Anthony
Old 06-24-2010, 02:38 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Anthony
Not likely, but not impossible, that it's the relay. I'd be looking more at the fuse and the wiring at the trailer connector.
Fuse or relay, look in the TIPM cover, and there is a map of the fuses and relays.
brad
Interested in one of my mods?
Old 06-25-2010, 10:34 PM
Tonatom Tonatom is offline
Vehicle: 2003 Dodge Ram 4.7L
Tonatom is on a distinguished road
2003 Ram 1500
I am having this Problem too, the brake and signals for right/left are not working at the incoming wires to the trailer connector, I went and tested for signal/brake on the Yellow-pink and White-pink lines further back from the taillight split offs in the wire bundle. The taillights work fine at the trailer connector.
Fuse 46 and 47 have constant power to them when the hazards are on so can I assume the relay is bad (but no power to the yellow and white pink wires at the back) This truck has never previously had a trailer hooked up to it. But how do I tell if the relays are working or not that the fuse 46/47 go to?
I just put the big Reese hitch on it.
Which Relay on the IPM controls these left/right lines? Or are these internal relays in the Front Control Module?
I also have a brand new C1 connector (the 15pin on the IPM) to put in as a couple wires were corroded badly.) This too could be the problem.
Old 06-25-2010, 11:21 PM
brad12kx's Avatar
Rep:2581
Originally Posted by Winchested View Post
2003 Ram 1500
First I should correct my earlier reference to TIPM. In your model year, that did not exist, but rather there is an IPM and a FCM.
I would expect the cover for the IPM to have a legend that shows which relays are for the turn signals. Another potential source for this legend is the owners manual. The trailer light relays are triggered by the FCM in your truck, so if a relay is not working, it could be the relay, but could also be the lack of signal from the FCM. If you do not operation of either turn signal on the trailer, I would be inclined to blame the FCM, as it is unlikely that both relays would fail at the same time.
If you can locate the correct relay(s), you can test for signal from the FCM. First remove the suspect relay, then using a volt meter, connect the negative lead to relay socket 86, and the positive lead to relay socket 85. This should show 12V pulsing at the same rate as the signal lights flash. NOTE - I do not recommend using a test light for this test. I do NOT know what electronics the FCM uses to trigger the relay, but can assume it is a low current ground switch (ie open collector, etc), and testing with a device that exceeds it's rated current WILL damage it fatally! A proper voltmeter is a 'current safe' test. If you are not 100% familiar with using a voltmeter, then testing of the FCM should be left for a trained technician.
As for the C1 connector, I do not know which connector ties the FCM to the IPM. If it is C1, then bad or corroded connections here, could yield the results you are noticing.
brad
Old 06-25-2010, 11:54 PM
So the FCM is the computer controller for the IPM found that out.
I have read over 30 posts on all kinds of forums about the IPM and FCM ****ing up so badly that they have to replace both at a whopping $400-$700. I can't believe Chrysler got away with not recalling these parts. What ******* engineer puts a fuse box/computer under the hood completely exposed to weather and shit like this fusebox. Epic fail on Chrysler's part, good thing this isn't my truck and these issues have turned me 100% off of buying a new dodge ram.
Old 06-26-2010, 12:51 AM
Anyone have a part number for the IPM and FCM 2003 Ram 1500 2wd 4.7 L auto w/ trailer wiring.
Or Can I just buy one of the aftermarket $50 controllers with the internal fuse/relay controls and run them right off of the rear tail lights?
