Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 > Exhaust
Exhaust 5.9L Exhaust Discussion
Old 04-07-2010, 04:43 PM
Ramrob Ramrob is offline
Vehicle: 1999 Dodge Ram 1500 5.9L
Rep:75
Ramrob will become famous soon enough
Default header bolts install
I changed out the hex head bolts that came with the headers for allen head stainless ones. I am having trouble with the 4th bolt from the front on both sides. Everything else was ok. I am having trouble getting the bolts started, I can't squeeze and apply pressure at the same time, it's tight. Any suggestions?
Old 04-07-2010, 04:56 PM
droshemiram's Avatar
droshemiram droshemiram is offline
Vehicle: 03 dodge ram HEMI
Color: atlantic blue
Rep:89
droshemiram will become famous soon enough
are the other bolts loose?
Old 04-07-2010, 05:41 PM
Rep:2657
Ramrod, put a small amount of anti seize on the first couple of threads, then take a semi stiff length of rubber hose that fits tightly on the bolts head & thread the bolt in as far as possible & then tighten it up using your allen wrench.
same thing works really well on spark plugs, i've been using that method for years
Old 04-07-2010, 05:49 PM
Rep:89
when i installed my headers I did the thread thing too but I did'nt tighten it up untill you put all the other bolts in,so nothing can be in the way like the gasket.
Old 04-08-2010, 07:59 AM
Rep:75
Are your are saying slip a peice of hose over the head so I can turn the hose?
Old 04-08-2010, 10:10 AM
Rep:89
no hes saying to get a hose that fits tight over the bolts head,but you have allen head bolts did you match up the gasket to see if they were the same?
Old 04-08-2010, 10:40 PM
Rep:75
Yes I bought them together as a set.(headers & gaskets) Got them on earlier today.
