Old 04-08-2010, 03:15 PM
tb08ram tb08ram is offline
Vehicle: 2008 Dodge Ram 1500
Color: Dark Blue
tb08ram is on a distinguished road
Default Removing Headlight (2008 Dodge Ram)
I'm needing help on removing my headlight.
I already removed the first (2) 10mm right when you open the hood
Here are my (2) questions?
1.) How do I remove the clip?
2.) how am I suppose to get to the last 10mm down by the wheel?
Old 04-08-2010, 03:17 PM
Rep:1625
Does this thread help? I hope it does
http://www.ramforumz.com/showthread.php?t=40569
Old 04-08-2010, 03:27 PM
Color: Dark Blue
I've already seen that I know where everything is I'm just need someone to explain to me how to do it.
I just wondering if someone who has taken thier headlights out before has any tips for the clip and the last bolt. Because I'm havin a hell of a time getting either one of them off.
Old 04-08-2010, 04:07 PM
Johns HEMI 2500's Avatar
Johns HEMI 2500 Johns HEMI 2500 is offline
Vehicle: 2007 Dodge Ram 2500 Hemi 4x4
Trim Level: SLT/TRX4 Off Road/SP
Color: Light Khaki Metalic
Rep:18
Johns HEMI 2500 is on a distinguished road
I have a 2007 and to get at the bolt by the tire you have to remove the plug and use a 4 inch extension
If You Can't Run With The Big Dogs, Stay On The Porch
Recon Smoked Cab Lights, Smoked Tail Lights. Big Rig Ice Running Lights, White Lightning Tail Gate Bar. Tech Tubes wheel to wheel nerf bars. 2" Revtek Leveling Kit. 35x12.5x17 Nitto Trail Grapplers
Old 04-08-2010, 07:23 PM
Color: Dark Blue
Well the last bolt there is a rubber inlet under the fender well that you can pull out and use an extension on and as for the clip you just cover your bumper with a towel and pull the headlight and it pops right out.
Old 11-25-2010, 12:35 PM
ICEMAN99TURBO's Avatar
ICEMAN99TURBO ICEMAN99TURBO is offline
Vehicle: 08 Ram
Trim Level: 1500 Big Horn
Color: Electric Blue Pearl
Rep:119
ICEMAN99TURBO will become famous soon enoughICEMAN99TURBO will become famous soon enough
Send a message via AIM to ICEMAN99TURBO Send a message via Yahoo to ICEMAN99TURBO
Correct me, yes no....there is a Youtube video on this?
Don't park in the ditch, that's not where you park, you park in a parking lot! .... Stupid!
Old 11-25-2010, 01:44 PM
The one in the wheelwell takes a 10mm socket on a 4" extension.
The two front ones are just torx head units, #27 I think.
Then I just used a small flat bladed screwdriver with a towel to lever out the headlight assy at the back side nearest the yellow reflector.
Here's a thread that may help:
Ram Mods
Old 11-25-2010, 04:47 PM
Vehicle: 08 Ram
Rep:119
Ram Mods
Thanks man... I even came up with this from this afternoon.
http://www.ramforumz.com/showthread.php?p=366832
Old 11-25-2010, 04:48 PM
I saw that. Nice writeup!
Old 11-25-2010, 04:58 PM
Vehicle: 08 Ram
Rep:119
Thank you sir.. I try to bring good info to the club and do what I can to help out.
