04 ram 2500 tranny problems!!!! HELP!!!!!!!!!!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 04-09-2010, 07:26 PM
ramman23 ramman23 is offline
ramman23 is on a distinguished road
Unhappy 04 ram 2500 tranny problems!!!! HELP!!!!!!!!!!!
I have a 2004 dodge ram 2500 with the 5.7l hemi .... I was driving up a bumpy hill and i hit a bump and plaaaaaaaa....i stopped moving!! It just makes a winning noise when i put it in ( park,reverse, drive, 2,1, 4 wheel drive ) nothing works ..... so long story short i had to get the truck towed.. and it sits at my house... could it be the transmission is done??? or maybe a vacuum hose or some kind of switch ??? i pulled the dip stick and there oil in the tranny and its not burnt.. At first i thought i snapped a U joint but everything looks solid... PLEASE HELP ME!!!!!!!!!!
Old 04-09-2010, 07:44 PM
Crawl underneath the truck and look for the wiring harness that goes to the tranny. Look to see that the connector hasn't come loose from the transmission case.
Old 04-09-2010, 10:44 PM
ill do that first thing tommorrow thank you very much !!!!!1any other ideas just in case??
Old 04-10-2010, 12:04 AM
Rep:1625
Welcome to the forum ramman23! Glad to have you here!
Old 05-01-2010, 01:14 PM
kmart6215's Avatar
kmart6215 kmart6215 is offline
kmart6215 is on a distinguished road
hey welcome to the forum! I have a 2004 slt 2500HD automatic but it is a 5.9L cummins and had a similar problem. the tranny would not shift in to 2,3,4th so i took it in to aamco and they said OH YES! NEW TRANNY! $3800.00! But i then went to a local auto mechanic that has been in the business for years and had contacts to check with and he told he that it was a simple problem but can run about $700. It was the shifting solenoid and vacuum governor that is attached to the transmission. that is what was bad and it did cost me $650.00 but that is less than $3800.00! hope that helps.
