Recommendations for Plugs? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum
Old 04-10-2010, 10:17 AM
Bellzy's Avatar
Bellzy Bellzy is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: SLT-Big Horn Edition
Color: Inferno Red
Bellzy is on a distinguished road
Default Recommendations for Plugs?
Gentlemen - any recommendations on a good spark plug? I have 39,900 miles on my '07...and for some reason, it seems to be running sluggish and getting poor mpg. Was thinking of starting with the plugs to see if that helps.
Also - does the '07 5.7L Hemi have an external fuel filter? Or is it inside the tank?
Thanks for your help!
Old 04-10-2010, 10:22 AM
drivehard27's Avatar
drivehard27 drivehard27 is offline
Vehicle: 2014 dodge ram
Color: Maroon
Rep:108
drivehard27 will become famous soon enoughdrivehard27 will become famous soon enough
Send a message via Yahoo to drivehard27
for spark plugs i would go with the bosh-4 plugs i put them in my truck and it runs good have gotten about 1 mpg better but i think that is because there new there about 5.99 per plug
Old 04-10-2010, 10:29 AM
Rep:1625
Have you checked your air filter? That might affect your MPG
Old 04-10-2010, 11:48 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I know you may like them but I know a few people that have run the bosch plats and have had issues with them (especially the performance modding crowd)...I did try those as well as iridiums, champ coppers...I now use ngks (5306's for stock an lightly modded, 4306's for the heavily modded trucks).. i have over 180k hard miles on my 05 an thats the only plug i'll use... and the only plug i tell the guys i do cam installs for to use as well
Old 04-10-2010, 11:51 AM
chefred112's Avatar
Rep:656
then again..im speaking from the hemi point of view..the 4.7 is totally different and the plats maybe good for it..
Old 04-11-2010, 12:06 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
I honestly think anything with more than one electrode is a waste of money. With my GM experience I have never seen any gains other than extra money being spent at the retailer. But if it worked for you then you must be one of the lucky ones.
Bosch double and quad electrode plugs caused problems on several GM engines from the '90s, including the LT-1, LS1 and Northstar. I've never heard of anyone having issues with NGKs. I would recommend NGKs or just regular OEM.
Old 04-11-2010, 12:45 AM
kevenj's Avatar
kevenj kevenj is offline
Vehicle: 2007 Ram 1500 QC 4x4 Hemi
kevenj is on a distinguished road
The maintenance schedule recommends replacing the plugs at 30,000 miles on the Hemi, because unlike the 4.7 (which uses double platinum plugs) the Hemi comes with basic copper core spark plugs.
I agree with the others recommending NGK; I haven't got enough miles on either of my hemi's to need plugs yet, but in any vehicle I've ever owned I've gotten excellent service with NGK plugs. Or just go back with the O.E. Champions, they obviously work well too. But I would stick to a basic copper core plug. Oh and remember you need 16 of them!
The only fuel filter is in the tank; Chrysler started doing this in the late 90's and while I think it's a dumb idea, it apparently works ok too. It's a very large filter. Have you checked or changed your air filter lately? That could be a major factor.
Old 04-11-2010, 02:04 AM
03ramit1's Avatar
03ramit1 03ramit1 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Silver and Dirt
Rep:20
03ramit1 is on a distinguished road
swap in a set of NGK 5306's (i just added a set to a truck reciently it was an 07) and they helped alot. his plugs were in the .060 range on the gap when we pulled them and they are suposed to be a .045. the NGK's are about 1.99 a plug so they are not too bad on cost.
Had a 12 second truck, now its a giant paper weight as of 1 may 10.
Old 04-11-2010, 03:50 AM
Rep:4311
Gotta agree with the NGK's, also. I have run the Bosch platinums before, but like Incognito, anything more than that is a waste of good money.
Old 04-11-2010, 07:50 PM
Bellzy's Avatar
Color: Inferno Red
Guys - thanks a ton!! I agree on the air filter and although it doesn't look too bad, I'm thinking of upgrading the whole intake. I will definitely look into the NGK's.
Also appreciate the feedback on the fuel filter! Wish they made things a little easier to maintain yourself.
You guys are the best - love this site!!
