Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 08-15-2010, 05:58 PM
Simcik Simcik is offline
Vehicle: 2010 Ram 1500 Quad Cab 4x4
Trim Level: Lone Star
Color: Light Graystone
Rep:20
Simcik is on a distinguished road
Aww, nice mod! LiveLink kinda through me off (it's call HomeLink), but glad I opened it! May do this mod myself...
Old 10-07-2010, 11:30 AM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
For those with security option group don't have to worry...
OPERATION
The HomeLink® transceiver receives battery feed through the Ignition Off Draw (IOD) fuse circuit of the vehicle. It operates on a non-switched source of battery current so the unit will remain functional, regardless of the ignition switch position. It can learn and store three separate transmitter radio frequency codes to operate garage door openers, security gates and security lighting. The Electronic Vehicle Information Center (EVIC) display provides visual feedback to the driver, showing which transmitter button is pressed. The system will not send operating signals if the vehicle theft security alarm is armed. This prevents a perpetrator from breaking into a vehicle parked outside a home and using the HomeLink® transceiver system to enter the home.
Old 10-11-2010, 12:00 AM
thewagon thewagon is offline
Vehicle: 2010 RAM 1500 QC BigHorn
Rep:35
thewagon is on a distinguished road
Thanks to this tutorial, I was able to hard wire my radar detector w/o running it along the windshield pillar and down under the dash.
Kudos!
Now to find a place for the GPS
Old 03-18-2011, 08:23 PM
ctilley ctilley is offline
Vehicle: 2010 Dodge Ram 1500 4.7 4x4
ctilley is on a distinguished road
Talking Awesome Info!!
Great info, I have been looking for just this type of info. Thanks a million for the great job!!
Originally Posted by Bock View Post
K, I have been griping about how to make the garage door opener on my 2010 Ram 1500 work only when the key is inserted. This is a safety thing for me as my truck is parked in the driveway. I got it. It involves cutting the power wire from the overhead console Livelink connector and then splicing in a wire from the power rear window switch, which DOESN'T work with the key removed. It took me about 30 mins, and I will try to explain here how I did it, any questions, feel free to ask.
This is how i removed the console. It just entails getting under it and pulling straight down. It has 4 brass clips that have to be unclicked, then it will come out.
Then kinda slide it towards the back of the truck to release the little feet at the front, then the assembly will hang loose.
Disconnect the 4 wconnectors and put the assembly aside.
This is the connector for the Livelink garage door opener. You will need to cut the RED wire, tape off the wire that is coming in, and then solder or splice a new wire that will go to the Power Rear window connector.
This is what it will look like.
Then route the wire to the red window connector.
The wire you will be splicing into is the pink wire in the middle. Splice the wire and seal it up with electricians tape.
This is what it will look like when you are finished!! Hook the connectors back up, reinstall the console and sleep safer at night, knowing that if some dirtbag breaks your truck window at night, at least he will not be able to get into your garage!!
Old 08-01-2011, 11:49 AM
jdshemi's Avatar
jdshemi jdshemi is offline
Vehicle: 2010 DODGE RAM CREW 5.7 HEMI
Color: SILVER
jdshemi is on a distinguished road
Default Overhead console harness
Need help really bad i let my 18 year old son try this on my truck he said he new how and messed up i need a new harness now do you know were i can get one or what the part number is. Can u look on your harness and tell me what part number is. I owe you one. Dodge cant find part number at all boooo
Old 08-01-2011, 02:25 PM
Rep:35
Question
Hi,
I have a 2010 Ram 1500....what is that round disk between the live link buttons and the rear window switch?
Thanks,
Andrew
Old 08-01-2011, 02:39 PM
11rambighorn 11rambighorn is offline
Vehicle: 2011 Dodge Ram 1500 Big Horn
Color: Deep Cherry Red Pearlcoat
11rambighorn is on a distinguished road
Originally Posted by thewagon View Post
Hi,
Thanks,
Andrew
It is the mounting disk for his Aftermarket GPS
3.92 LSD, Skid Plates, Bed Liner, 275/65R20 Goodyear Duratracs
Old 08-01-2011, 06:54 PM
Rep:35
ahhh, thank you!
Old 09-05-2011, 05:44 PM
nnjramspeed nnjramspeed is offline
Vehicle: 2011 RAM 1500 Sport
Color: Burnt Cherry
nnjramspeed is on a distinguished road
nice Thnaks for the info!
Old 03-30-2014, 11:20 PM
RamOnTheHill RamOnTheHill is offline
Vehicle: 2013 Ram SLT
Rep:18
RamOnTheHill is on a distinguished road
Does anyone know if there are any changes on the 2013 RAM? I'd like to do this mod on mine.
