Steering play - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-10-2010, 03:48 PM
08quadram's Avatar
08quadram 08quadram is offline
Vehicle: 08 Ram Quad 1500
Color: silver
Rep:22
08quadram is on a distinguished road
Default Steering play
How much side to side movement is normal with the steering rack on these. Mine has about 1/4" to 3/8" at the outside edge of the tire when I try to turn the wheels left or right from the tire. Also there is a "clunk" when I turn the wheel at the end of the "play". I don't know much backlash would be normal. I wouldn't think there should be any side to side movement. I don't recall having any on my ford freestyle.
Mike
'17 Ram 1500 Big Horn Crew, 5.7 Hemi, 3.92 axle
"Meddle not in the affairs of dragons, for thou art crunchy and good with catsup" -Doc, IFSJA
Old 04-10-2010, 11:49 PM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
I think it would be more important to inspect the vehicle's steering, suspension and driveline components carefully to see whether the play that you've discovered is going to cause a problem. Overall I can't tell you how much play you should have, I think Remerson should have an idea. But a good visual inspection should tell you what kind of condition your truck is in.
Old 04-11-2010, 08:51 AM
iRESQu iRESQu is offline
Rep:2217
I had a thunk and a loose steering also, told a service mgr friend of mine and he took a look. He determined, in my case, that my pittman arm was REALLY loose. Apparently when my steering gear box had to be replaced, they didn't tighten the pittman arm thoroughly.
