Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-10-2010, 06:05 PM
juniormag juniormag is offline
Vehicle: 2002 Dodge Ram 1500
juniormag is on a distinguished road
Default Heater and AC control problems
im having problems on witch direction the air shoots out of i only works on defrost could it be the control switch?????
Old 04-10-2010, 09:35 PM
m88tow m88tow is offline
Vehicle: 2000 Dodge Ram 2500 4x4
m88tow is on a distinguished road
It could the switch or it is a blend door problem.
Old 04-19-2010, 11:35 PM
Ted's Avatar
Ted Ted is offline
Vehicle: 2001 Sport Dodge 1500 5.9L
Ted is on a distinguished road
Mine did that. It was a broken mixer box. It's made out of plastic. You have to REMOVE the dash to get to it. Drop the steering wheel, unbolt the dash and have little bity fingers. I had some one do it. Also, there is a vacuum thing that works with it. Check that first. It's NOT a cheap fix. I'd step on the gas, and the air would go to the defroster, then when I let off the gas, it would come back out the dash vents. Then it quit. I had the vacuum thing fixed, then the mixer box thing took a dump. Yes, you need the BIG wallet. Sorry for the bad news. However, it has been working fine for six months now. Just throw money at it.
Ted
Old 04-19-2010, 11:37 PM
Thread moved to proper section.
Old 04-20-2010, 01:48 AM
i was just reading other threds and saw thid might be a recall but not sure
Old 04-25-2010, 11:48 PM
EARLJAM's Avatar
EARLJAM EARLJAM is offline
Vehicle: 1998 Dodge Ram 1500 Quad 4x4
Trim Level: SLT Laramie
Color: Intense Blue Pearl
EARLJAM is on a distinguished road
id check the vac valve first. its under your hood near the firewall i believe.
1998 Dodge Ram 1500 SLT Laramie 5.9l Intense Blue Flowmaster Exh. more to come.
Old 04-27-2010, 04:10 PM
New95Ram New95Ram is offline
Vehicle: 1995 Dodge Ram 4X4
New95Ram is on a distinguished road
Let us know what it turns out to be. My truck is doing a similar rerouting of A/C. Haven't had it looked at or anything yet.
Old 04-27-2010, 09:34 PM
bosswillys bosswillys is offline
Vehicle: 1997 dodge ram sst
Color: primer
bosswillys is on a distinguished road
I had the same problem, and mine was a simple and FREE fix! On the passenger side of the fire wall there is a very small diameter vacumn line. Mine was broken and I could not find anything small enough to insert in the tube to fix it. I slid a piece of heat shrink tubing over it, and pushed it together, then heated it with my lighter. The switch has worked fine ALL WINTER!
Old 05-02-2010, 08:42 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
There is no recall for it but there is a TSB for that repair. The 98-01 are notorious for this problem. Started after Dodge changed the dash in 98.
www.beatcraigslist.com - for posting dangers & secrets
Old 05-13-2010, 10:05 PM
rustyolred's Avatar
rustyolred rustyolred is offline
Vehicle: 1997 Ram 1500 ext cab 4x4
Rep:20
rustyolred is on a distinguished road
Send a message via AIM to rustyolred
I am having probs with my 97. Is there a vac diagram that shows where I should look to see if I have a vac prob?
