Old 04-10-2010, 09:15 PM
kjc63's Avatar
kjc63 kjc63 is offline
Vehicle: 2009 Ram 1500 4x4
Rep:19
kjc63 is on a distinguished road
Default Debadge Problem
Wondering if anyone can help me. I debadged my 2009 Ram Sport today. It went ok until I took a look afterward. I can easily see where the badges were, almost like its a totally different color. I was wondering if anyone has any suggestions on how to get rid it, or do I need to put the badges back on? I have tried polishing and waxing and even rubbing compound, none make any difference. Thanks.
2009 4x4 Ram Sport Inferno Red: Mufflex 14", Color Match Grill, REN upgrade, Iron Cross black steps, 4" Mopar suspension lift, 35" Procomp Xtreme Ats, Bushwhacker Pocket Flares color matched, All badges "Blacked" out, k&n drop in filter,Bedrug, Extang Trifecta Tonneau cover, XD Monsters 20"
Old 04-10-2010, 09:29 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
i wouldnt know but it probably needs to just fade
Old 04-10-2010, 09:31 PM
I push the skinny pedal
Rep:3277
I was able to remove the outlines by using a scratch remover followed by a polish then wax, worked for me. it will eventually even out with the rest of the paint after a couple of applications.
Kurtis
Old 04-10-2010, 10:00 PM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
Sounds to me like you just have a little adhesive left on the surface. Just put a little Gasoline on a clean cloth & wipe over the area, maybe once or twice . Good luck & let us know how you go on......
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Old 04-10-2010, 10:04 PM
col's Avatar
col col is offline
Color: Black & Gold
Rep:92
Show us some pic's kjc63........Should be no lines on a 2009
Old 04-10-2010, 10:31 PM
Some of the surrounding paint, that wasn't covered, probably faded a bit. The uncovered portion will eventually fade as well.
I had a bit of a different issue but a good cut & buff, with wax and polish afterward, fixed that.
Old 04-11-2010, 03:39 AM
silvermist's Avatar
silvermist silvermist is offline
Vehicle: 08 dodge ram quad cab 1500 4x4
Trim Level: sport
Color: sunburst orange
Rep:37
silvermist is on a distinguished road
either that or you seeing a wax build up, go get a wax and grease remover cloth from a automotive place like canadian tire or pep boys and wipe the are and then wipe dry with a clean lint free cloth then hit it with a sratch remover and then wax the area and it should make it less noticable.
Old 04-11-2010, 04:13 AM
Fury's Avatar
Fury Fury is offline
Vehicle: 2010 Dodge Ram Crew Cab 2WD
Color: Mango Tango Pearl
Rep:103
Fury will become famous soon enoughFury will become famous soon enough
Not sure if you got all the adhesive off. Did you use Goo Gone? It will take all the adhesive off. Then wash the truck and add some wax to that section.
It might be from your truck being Red. I know in the past when I've done silver I haven't had any problems.
2010 Ram 1500 Crew Cab Sport, NAV, Alpine, Rear Cam, Remote Start, Performance Hood, Mopar Side Steps, Adjustable Pedals, Leather Bucket Seats.
Mod: DSP, 14" Magnaflow
Old 04-11-2010, 08:53 AM
kjc63's Avatar
Rep:19
I definitely got all the glue off, I used adhesive remover for decals (basically Goo Gone), and it is more than just outlines. The entire area that was under the badges looks like a different color, actually is more faded looking than the exposed paint. You can easily see the words RAM and HEMI now on the side of my truck. I will try to get some pics when the wife brings our camera back from her trip to NYC. Thanks for all the info, the only thing I can try is scratch remover, but I already tried polishing and waxing and that didn't make any difference. I am considering painting the decals black and putting them back on, although I prefer the de badged look.
Old 04-11-2010, 09:09 AM
Fury's Avatar
Rep:103
You may want to try and claybar that area and then wax it again. I love the debadge look myself. I took the RAM off, but the hemi is coming of soon.
