Old 04-10-2010, 11:49 PM
THESANDMAN THESANDMAN is offline
Vehicle: 2010 RAM 1500
Trim Level: SLT 5.7 HEMI
Rep:21
THESANDMAN is on a distinguished road
Default Painting the mirrors
i would like to have my side view mirrors painted to match my car . they are black . i was wondering if anyone here has had them done . the texture of them looks like they wont hold the paint. if it can be done i would have a pro shop do it but i dont want them to rape me on the cost of having them done . so i would like to have knowledge about the procedure. so my question is there alot of work to get them painted . or would it be simple process of prep and paint.
Old 04-10-2010, 11:50 PM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
You can have them done but you have to sand it down quite well, use a special primer meant for non-metal surfaces and a paint that has flex agent in it.
Old 04-10-2010, 11:54 PM
I push the skinny pedal
Rep:3277
I did my aftermarket mirrors; had them colormatched when I was having my door panels repaired. If you want to save the money, get 3 cans of rattle can paint from the dealership, sand the finish down with 300/600/1000 grip papers, use an adhesion promoter, then paint, followed by 2 coats of clear. Wet sand with 1500/1800 grit to get rid of any orange peel. If they're still on the truck, a shop might charge you $400, but drop them off and I'm sure you can get them done for $100-150 each
*edit*
To add to Incog's, the dealership rattle cans seem to work pretty well for flexibility on plastic parts; used it to good results on many of mine.
Kurtis
Old 04-10-2010, 11:59 PM
Incognito's Avatar
Rep:72
When I worked for GM we used Sikkens paint. It was expensive stuff, but damn was it fantastic. Far better than PPG, which I personally think is overrated. DuPont is damn good too, depending on which line of paint you choose. And stay away from Sherwin Williams, that stuff is s**t.
Old 04-11-2010, 12:03 AM
Rep:21
thanks for the quick replies, im glad it can be done and that it has been done. i wont attempt it my self but at least i know that i can save some money if i just take the mirrors off, thanks again. i can put this at the top of my mods list , since its not to expensive
thanks again
Old 04-11-2010, 10:37 PM
MTtruckr's Avatar
MTtruckr MTtruckr is offline
Vehicle: 2009 Ram 5.7L
Trim Level: Big Horn Package
Color: Stone White
Rep:50
MTtruckr will become famous soon enough
What about buying the aftermarket covers, like on the Laramie model, and either go with the chrome, or see if those can be painted?
BDS 6 inch. Fox 2.0 rear. Toyo MT 35x12.50x18. Yukon 4.56's. Detroit Truetrac. Mufflex 18. Airaid CAI.
Old 04-12-2010, 05:25 AM
Rep:21
i thought about that but the thing about those covers is that the arms are still black i would like the whole mirror painted.
