Old 04-12-2010, 12:51 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
pretty easy when you do it a few times.. here is a quick synopsis..
-drain oil and radiator
-disconnect an remove radiator, move tranny cooler and ps cooler off to side, remove cross member
-remove cai, valve covers, alternator, unbolt and hang ac compressor (don't forget bolt behind compressor), unbolt and move to side the power steering pump
-remove egr, coil packs an valve covers
-remove valve rocker arms and pushrods
-with the chrysler specific harmonic balance puller (only real custom tool you'll need), pull the crank pulley as well as other 2 pulleys on timing chain cover/water pump
-unbolt an remove timing chain cover (don't forget bolts coming up through oil pan)
-release tension on chain tensioner, unbolt cam bolt and pull timing sprocket off and place to side, then unbolt an remove tensior plate
-spin the cam a few times to push lifters out...put cam bolt back in a few turns, pull cam out
-lube new cam and slowly insert
-go backwards from here..the key is to either degree the cam or use marking points cuz the chain has to go on exactly right or timing will be off..
this is the basics..obviously there are specific details I left out but you get the idea
Old 04-12-2010, 02:05 PM
chefred112's Avatar
Rep:656
Originally Posted by droshemiram View Post
Cool I know you know some guys in AZ you think they will help me when Im ready? Im going to meet up with some this saturday.
right on...look for chris an steve (they are both members on here)..chris is the master (silver 04 qc with a black srt10 bumper)...they are the 1st 2 trucks in the pic..
Old 04-12-2010, 11:28 PM
lifted03HEMI's Avatar
lifted03HEMI lifted03HEMI is offline
Vehicle: 2003 Dodge Ram
Trim Level: Laramie 4X4
Color: Midnight Blue
Rep:19
lifted03HEMI is on a distinguished road
Thanks for all the input. I haven't decided on a brand yet. I am looking at the "Spartan" cam, does anybody have any experience with it?
Old 04-12-2010, 11:32 PM
chefred112's Avatar
Rep:656
I run the Spartan..the fastest stockblock na qc in the 1/4 also runs a spartan...if and when you do buy, make sure you ask Stu to grind it with an lsa that works with your year pcm..
Old 04-12-2010, 11:45 PM
Rep:19
Did you replace you valve springs and push rods? And do you think my Superchips will be good enough to tune after installing the cam?
Old 04-12-2010, 11:51 PM
chefred112's Avatar
Rep:656
because of the lift you WILL have to do at least 6.1 valve springs and pushrods. The superchips will work but you have to tell Stu what you have in terms of mod, tell him because it's an 03 that it can't be custom tuned (but I'm sure he already knows that), he will grind it to an lsa that is pcm friendly...and if you wanna know what it sounds like...
Old 04-13-2010, 12:01 AM
Rep:19
That sounds amazing...what kind of power did you pick up?
Old 04-13-2010, 01:41 AM
chefred112's Avatar
Rep:656
last dyno I did before custom tuning was 370hp/390 lbs tq
Old 04-13-2010, 08:15 PM
Rep:19
Well I have decided on the Spartan, now I just need to find somebody around here that can help me do my first install.
Old 04-13-2010, 08:26 PM
chefred112's Avatar
Rep:656
..where are you located..might be able to find someone for you...
