Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Old 04-12-2010, 03:29 PM
Indeepcamo's Avatar
Indeepcamo Indeepcamo is offline
Vehicle: 2010 2500 Mega Cab
Rep:30
Indeepcamo is on a distinguished road
Default Fuel Question
No doubt this has been discussed before but just curious as to type of gas folks are putting in the 5.7L. The owners manual says 87 is okay but 89 is recommended. I went with the 89 as it is second tank of gas and figured why not. But if most are running 87 and not having issues than maybe I should save the money per gallon and spend it on Mods!!!
Old 04-12-2010, 03:39 PM
CanadianInfernoRed's Avatar
CanadianInfernoRed CanadianInfernoRed is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Color: Inferno Red
Rep:22
CanadianInfernoRed is on a distinguished road
I run 87 and I on my last road trip I got 23 mpg ... granted I was doing 55 mph but still 23 mpg is pretty good and the truck is so comfortable that I did not mind going that slow.
2010 Dodge Ram 1500 SLT Crew Cab 4x4, 5.7L Hemi 390 hp 407 lb/ft
Rep:2657
I use mid grade myself, but, my Harley drinks supreme
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
i only use 89 when i tryed 87 my truck felt and ran very sluggish
Old 04-12-2010, 04:09 PM
glamontagne's Avatar
glamontagne glamontagne is offline
Vehicle: 2009 Dodge Ram Crew
Rep:55
glamontagne will become famous soon enough
I use 87 and I notice no difference from the higher octanes.
Gary--2009 Black Ram Crew 5.7 Truck Champ Stainless tube steps,Tekstyle Tonneau Cover, LED Interior, LED License Plate Lights, LED Reverse Lights, LED Cargos, 5900k Headlights and Fogs.
Old 04-12-2010, 06:03 PM
Luke's Avatar
Luke Luke is offline
Trim Level: SLT plus
Rep:20
Luke is on a distinguished road
I use 89 cause I'd rather not risk spark knocks, I like my truck way to much, I don't cheap out on my beer and rum and that just goes to say I won't on my fuel either, I intend on keeping it for a while. I don't drive my truck hard enough to notice a difference in performance, but in my humble opinion why spend that much on something that nice and leave to chance any ill effect the lesser fuel may have.
Old 04-12-2010, 06:19 PM
Cormacs's Avatar
Cormacs Cormacs is offline
Trim Level: Crew Sport
Rep:14
Cormacs is on a distinguished road
87 will have absolutely no ill affect on the truck. Spark knock is a thing of the past with the new electronic ignition and timing. 89 will actually cause more carbon build up then 87 and will increase service interval on spark plugs and fuel injector cleanings. I use 87 and it runs perfect. I would never put a higher grade in unless it called for it. The owners manual says 87 so I use 87.
Old 04-12-2010, 06:47 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
The manual actually says that 87 is ok but 89 is what is recommended for best performance.
Direct from the Owners Manual:
The 5.7L engine is designed to meet all emissions regulations and provide satisfactory fuel economy and performance when using high quality unleaded gasoline having an octane range of 87 to 89. The manufacturer recommends the use of 89 octane for optimum performance. The use of premium gasoline is not recommended, as it will not provide any benefit over regular gasoline in these engines.
When towing, I notice a difference when using 89 over the 87 in performance and MPGs.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 04-12-2010, 07:05 PM
Cormacs's Avatar
Rep:14
89 will burn slower. We have seen issues with people running higher octane gas unneccisarrily and needing maintenance at smaller intervals. If the manufacturer says either is ok I would run the lowest ocatane and not just for the price difference. I don't tow a lot with my truck and I don't race it. The slower the fuel burns ( higher ocatane ) the more carbon produced and therefor more carbon build up. We have always seen vehicles that run high octane fuels such as R/T vehicles will aquire more carbon and require injector services and spark plugs at smaller intervals. The higher octane will only help you under high compression situations such as heavy towing and full throttle where you are useing the engine to it's full protential. Otherwise you are just burning money.
Old 04-12-2010, 08:34 PM
ScatPak07's Avatar
Rep:970
I would put 91 or 93 in your tank! That will help maintain your new truck and keep the motor clean and the fuel burning better! I have never put anything less than 91 octane in my truck since I got it.
You will be putting $10 more in the tank and it will keep the truck running better and also give you some more pep! I do not know why anyone would not, but that is just me!
Just trying to talk some sense into everyone haha
If you get a programmer it makes a big difference what fuel you put into the truck
