Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 04-14-2010, 05:29 PM
bones06's Avatar
bones06 bones06 is offline
Vehicle: 2008 Ram 1500
Trim Level: SLT Big Horn QC
Rep:92
bones06 will become famous soon enough
Default New Issues on '08 1500
I noticed after a pretty good rainstorm a few weeks ago that the rear underseat storage compartment was full of water. M power rear window was not open nor were any other window either. Is this a common problem for this year of truck? Also noticed that my rear bumper is really starting to rust from the backside and has now crept to the outer edges. It is also starting to rust all around the black plastic step trim on the top of the bumper. I am thinking this should be covered under the warranty which I have 9 months left. I will get pics up soon as I can to show you the rust.
Magnaflow SI/SO Smoked stainless tip, Anzo LED Lightbar, Spectre Profab #9932 CAI. Euro Dezigns Xenon Krypton 8500k, Stampede Pocket Style Fender Flares, Bilstein 5100 series shocks, VHT Niteshaded Tail Lights and 3rd Brake Light, 295/70/17 Nitto Trail Grapplers MT/XD Spy Wheels
Old 04-14-2010, 05:33 PM
Rep:1625
It can't hurt to contact your dealer, that's pretty serious stuff. I'd get that taken care of ASAP, that water can cause major headaches
Old 04-14-2010, 05:35 PM
Resident Technician
Rep:1909
I'm thinking your corrosion warranty should be for 10/100k.
Old 04-14-2010, 05:54 PM
beermanjoe's Avatar
beermanjoe beermanjoe is offline
Vehicle: 2007 Ram
Rep:25
beermanjoe is on a distinguished road
Better get it looked at before your 36,000 3yr warranty is up. I believe for it to be covered under the corrosion warranty it must be rusted completely through.
Old 04-14-2010, 05:59 PM
Rep:2705
Bones, i copied this off a website
2008 Ram 1500
I bought this ram new and in less than 3 months started to leak water in the rear floor.They found the factory had made a mistake when they sealed the seams. So the window was removed and the seams were fixed and repainted and a new rear window was replaced. It stopped leaking for a short time.Then started again the rear window was replaced again. The sliding window seal was leaking I was told.Then it went back to leaking water in and the dealer replaced the cab vents said the were not aligned right,and had the third light resealed with clear rtp.Now It is still leaking and they have no clue. They sent a water leak expert to my house and they still don't know where its coming from and now the interior stinks.
that was just 1 of the several postings about it
someone in here posted about basically the same thing
http://www.ramforumz.com/showthread.php?t=43749
Old 04-14-2010, 09:29 PM
bones06's Avatar
Rep:92
Thanks for the replies guys, and gtyankee that has got me a bit worried. I am going to get this sucker into the dealer asap! I love this truck but man this crap shouldn't be happening when I only have 15,600 miles on it. I had to have both front tie rods replaced this winter, my tire shop went to rotate the tires and said that both sides were loose as hell. Took it to the dealer and they said both were defective and close to coming apart. Hopefully they get this figured out, or it's going to be turned in.
Old 04-14-2010, 09:43 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
well good luck i hope they fix it for you
