Old 04-14-2010, 05:14 PM
Silver05Ram's Avatar
Silver05Ram Silver05Ram is offline
Vehicle: 2005 Dodge Ram
Rep:98
Silver05Ram will become famous soon enough
Exclamation Painting chrome rims to black???
Ok, I have the stock 20s painted black over the chrome. The original owner of rims didnt do any prep work, so I have crappy spray paint on these rims. I am using Aircraft Remover and steel wool. This sh!t is hard and time consuming. i'm going to get all the paint off and scuff and roughen up the chrome and repaint black(paint won't stick to chrome). Any tips or suggestions, that can be done at home. If anyone has used the aircraft remover how did it work for you?? I am having trouble with it, I already started one rim, so theres no backing out now...
35" Mickey Thompson ATZ's/stock 20's painted black. Tinted Tails. Dynomax Bullet Resonator. LED's inside cab. Debadged. 12k Hid's
Old 04-14-2010, 05:34 PM
Rep:2642
I got this off of another site, it may help you
some good sandpaper to get some scuffing, then I put on 2 coats of adhesion promoter which I picked up at Autozone. That was followed by 2 coats of rustoleum primer, 2 coats of flat black and 2 coats of clear
Old 04-14-2010, 08:06 PM
I push the skinny pedal
Rep:3277
I'm also a fan of acid etching before I prime. You can pick up muriatic acid at any paint store, and it etches the surface in a way that no sand paper can match. leaves you with a smooth looking surface, but it's highly micro-texturized and has great bonding. The acid etch removes the need for adhesion promoters.
Kurtis
Old 04-14-2010, 08:56 PM
Rep:98
Well, I have tried the Aircraft Remover in a Spray Can and it sucks. It says to leave on for 10 min, then wipe away. I did so and the paint turned into tar and made it 10x harder to get off than it was. So now I'm stuck with steel wool and a tar puddle. I went back to the store and got Aircraft Remover in a Jug that you brush on. MUCH BETTER. But, you have to use ALOT, and wipe it away within a minute or so, or it will turn into tar. Lol At the rate my prepping process is going, I won't have all 4 rims done until about 2 weeks from now, and I'm being serious. I did 4 hours of work today and I got half a rim done with blotches still everywhere that I have to go back and touch up.
Does ANYBODY have any advice?? I really need it, this sucks. I need some help on speeding this process up.
Old 04-14-2010, 09:39 PM
How about sand blasting to roughen up the surface ?
Old 04-14-2010, 09:56 PM
ScatPak07's Avatar
Rep:970
That would definitely make it rough! I would have got the paint off and then used steel wool or sand paper.
If you want to get serious grab a orbital sander or hand sander. That will get you a rough surface haha
BEst of luck to you man!
Old 04-15-2010, 05:17 PM
Rep:2642
if your tires are off of the rims, & hopefully they are, because i believe that or any paint remover is bad for paint, rubber, & plastic
spend the money & get them MEDIA blasted, that can be done with walnut shells, sand, baking soda, plastic, glass, lead silicates, etc.
I always used DADs easy spray myself, almost all hardware stores carry it
Old 04-17-2010, 09:58 PM
DODGE4x4's Avatar
DODGE4x4 DODGE4x4 is offline
Vehicle: 2006 Dodge Ram 2500 4x4
Trim Level: slt big horn
Color: tan
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Rep:82
DODGE4x4 will become famous soon enough
ill have to agree with tom on getting them sand blasted.
Old 04-18-2010, 07:26 AM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Have you tried any good quality Paint/stain stripper??????? Just a thought.
Old 04-19-2010, 12:21 AM
Vikefan4eva's Avatar
Vikefan4eva Vikefan4eva is offline
Vehicle: 2004 Dodge Ram 1500
Rep:22
Vikefan4eva is on a distinguished road
Sounds like you're havin' a hell of a time.
2004 Dodge Ram 1500 ST 4x4 QuadCab
MODS: Interior LEDS, Underseat Dual Sub Enclosure, Alpine Type-S 10" Subs, Polk Audio PA600.1 Amp, Alpine CDA-9856 HeadUnit, Painted Bumpers and Grill, and soon to be much more!!!
aircraft remover, chrome painting, chrome to black, painting chrome rims
