Old 04-15-2010, 05:50 PM
Ramrob Ramrob is offline
Vehicle: 1999 Dodge Ram 1500 5.9L
Rep:75
Ramrob will become famous soon enough
Default Front end shaking/vibrating when I brake
I thought I needed pads and rotors when my truck started to vibrated when I braked. The steering wheel shakes too(only when I brake). Alignment and balancing is good with the tires. Noticed it about a 2 months ago. I replaced the wheel bearing last year and didn't have the abs sensor hooked up so all winter it's only been pumping one side. I pulled the abs fuze when it started thinking it was that. Still does it and was just going to order new stuff but just checked the brakes. Rotors aren't bad at all, I've seen way worse, only have one tiny groove on the outer driver side. Pads are about 50% or so, rears look even better. ???????????????
Old 04-15-2010, 06:22 PM
Resident Technician
Rep:1915
Have you actually measured lateral runout and thickness variation on the rotors?
Old 04-15-2010, 06:35 PM
droshemiram's Avatar
droshemiram droshemiram is offline
Vehicle: 03 dodge ram HEMI
Color: atlantic blue
Rep:89
droshemiram will become famous soon enough
you need new rotors they are warped my truck had the same symptoms I got them resurfaced did'nt work had prenty meat on it but it was still warped ,just bought new rotors smooth.[IMG][/IMG]
Old 04-15-2010, 06:54 PM
drivehard27's Avatar
drivehard27 drivehard27 is offline
Vehicle: 2014 dodge ram
Color: Maroon
Rep:108
drivehard27 will become famous soon enoughdrivehard27 will become famous soon enough
Send a message via Yahoo to drivehard27
ya sounds to me like they are worped but on the other hand there is a thing i found on a recall site about the qc trucks vibrateing when brakeing and the dealer has a fix for that now it is not a recall they just now how to fix it if it is not under warenty you will have to pay my qc is doing the same thing and im going to take it in soon it has new brakes all the way around
Old 04-15-2010, 10:46 PM
Replace or have the rotors cut .
Old 04-20-2010, 11:40 PM
Rep:75
I figured they might be warped. I went out and bought a set the night I posted this.
Old 04-20-2010, 11:47 PM
Rep:89
so did it fix the problem?
Old 04-09-2011, 10:25 PM
OBBN OBBN is offline
Vehicle: 2006
Trim Level: Base
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
OBBN is on a distinguished road
Hey Guys,
The problem is the way the discs are turned when doing a brake job. I went through 2 sets of stock rotors and 1 set of EBC rotors before finding the problem. EBC clued me in on what was happening.
The rotors MUST be turned while on the truck. There is a special machine to do this with and not all dealers have this. If you turn the rotors off the truck they WILL warp within 15k miles and you will be right back where you started.
It really angers me to know that the Dodge dealer knew nothing of this (or did know and just kept taking my money to fix the rotors every 15k)
Anyways, hope this helps.
