Predator U7137 ? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 04-16-2010, 04:50 PM
RI 06RAM's Avatar
RI 06RAM RI 06RAM is offline
Vehicle: 2006 dodge ram quad cab
Trim Level: sport
Color: grey
RI 06RAM is on a distinguished road
Send a message via AIM to RI 06RAM
Question Predator U7137 ?
hi guys i just bought my o6 ram quad cab an got a predator i was woundering if any one has made any custom tunes to get a lil more a push the truck a lil more maybe with some timing an spark ? any in put would really help thanks guys
06 q/c ram sport, pioneer in dash chrome steps an door handles,k&n cai an predator 7137
Old 04-17-2010, 10:25 AM
RI 06RAM's Avatar
Trim Level: sport
Color: grey
Question need a lil help with the predator
any input would be great guys i really wanna push the truck a lil more but i dont wanna hurt it so i need to knw how much fuel an timing an rpm i can give it thanks
Old 04-17-2010, 10:32 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
There are some members with custom tunes on here, but I'm pretty sure they had a certified Diaplosport tech create the tune for them. You may want to get with DS and get more info, they will need to know some specifics to get you a proper and safe tune.
Old 04-17-2010, 12:02 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
...agreed..I had my truck custom tuned...you can do it through email to almost any cmr tuner. you use the diablo to datalog and send it to them and they will send back a tune to upload in truck. the stuff you can play with is the wot settings...need a wideband to see how your truck runs in open loop.. I understand adding or pullin fuel, but not spark adjustments..
Old 04-17-2010, 12:30 PM
RI 06RAM's Avatar
Trim Level: sport
Color: grey
Default thanks for the help
hey guys thanks for the help im goin to put on the k&n cold air intake an the flowmaster 40 on then bring the truck to a local dyno tuning shop where i got the predator from an see what he can get out of it but for now how high can i set the rpm shift points ? so that i dont hurt the truck well thanks for the input i love the site u guys are all helpful thanks
Old 04-17-2010, 12:37 PM
Set your WOT shift points a couple of hundred RPM below the redline so you don't hit the rev limiter all the time.
Don't adjust WOT spark and fuel parameters until you know what the engine is doing at WOT. You'll get that info on the dyno.
Shoot for a 12.5 to 12.8 air fuel ratio at WOT. That seems to be the sweet spot for fuel to the HEMI. Of course, all engines are a bit different so your WOT air fuel ratio may be a bit different.
Remember, when measuring air fuel ratios, the lower the number the richer the mix, the higher the number the leaner your fuel mix is. I suspect that the truck, with the stock program, is probably around the high 13, low 14 measurement.
Too lean and you'll be knocking and the PCM will pull timing and fuel to eliminate knock and that will reduce HP output.
Is your local shop a DiabloSport authorized CMR tuner? If so, yer set as they know how to tune using the DS software.
If you get a CMR tune, don't forget to back it up on a thumbdrive and put it on your HD. Also, it's a good idea to extract your stock tune and save it as well just in case!
Old 04-17-2010, 01:11 PM
RI 06RAM's Avatar
Trim Level: sport
Color: grey
hi a thanks for the info an yes they are a dealer for diablo sport i have already spoke with them so ill just have them fine tune the truck thanks again
Old 04-17-2010, 10:15 PM
chefred112's Avatar
Rep:656
do you have the flow 40 yet, if not, do a different muffler if your looking for performance..flows are a good sound at idle and part throttle, but for performance it doesn't compare to magnaflows or gibsons or dynomax's
Old 04-18-2010, 05:15 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
krc performance marty or sean
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 04-18-2010, 07:48 PM
RI 06RAM's Avatar
Trim Level: sport
Color: grey
no i dont have the flowmaster yet i was planning on that system cause i want some thing loud so witch system is better?
