Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 06-19-2010, 09:47 PM
firemannglobe firemannglobe is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
firemannglobe is on a distinguished road
I have a new 2010 crew cab Laramie, I have the rattle in the passenger seat. I know it is coming from the seat back because you can push against it when it is rattling and it will stop.
Old 06-22-2010, 07:59 AM
agjames agjames is offline
Vehicle: 2010 , crew cab, 1500
Color: inferno red
agjames is on a distinguished road
I thought that i had a rattle in that seat or right side door, i took it to the dealership for service & asked about it, turned out that on mine, it was the seat beat buckle hitting against the door post
i had the same problem. the seat belt buckle was turned and rattling. drove me crazy for a week before i figured out what it was...
Old 06-22-2010, 08:12 AM
Mojamz's Avatar
Mojamz Mojamz is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Trim Level: Laramie Crew Cab
Color: Bright White Clearcoat
Rep:25
Mojamz is on a distinguished road
Mine did the same the thing...it was NOT the seat, it was the seat belt. Just move the seat belt off the seat back so it stows properly between the side of the seat and the pillar...this should do the trick.
Old 06-23-2010, 09:54 AM
longbow longbow is offline
Vehicle: 2012 Dodge Ram 1500
Color: Molton Red and Silver
Rep:37
longbow is on a distinguished road
Default It may not be the seat belt it could be under the seat
Hey guys check under your seat , you will find the lock for your rims . They put it in a plastic bag zip tied it to the jack and it rattles like HELL down there . I pulled mine out and placed in a cloth bag under my center seat. Oh buy the way if you ever need to use the Jack under the passenger seat , good luck with that damn cheap thing . I suggest tossing that and buy a cylinder jack .
Old 06-24-2010, 12:35 AM
HEMI5150's Avatar
HEMI5150 HEMI5150 is offline
Vehicle: 2010 Dodge Ram Quad 4X4
Trim Level: SPORT
Color: Black Pearl
Rep:35
HEMI5150 is on a distinguished road
Same issue i had...rattle with front passenger seat area, BUTTTTTTT, like your`s, same problem found before i went to the dealer, found seatbelt buckle was bangin on the side piller post because passengers aren`t smart enough when they get out of the truck to PUT THE SEATBELT back in the factory position...good thing we dont let THEM drive huhhhh...lol. Dealerships scare me, most of those dealer "parking lot boys" are dumber than sh-t that are allowed to work on your trucks. So i`m VERY glad i found the problem before having to deal with the stupid dealership.
So to the other guy....check ALL your seatbelts first...correct position...?
Put a wrench on the mounting bolts, are they all tight...? (probably are)
Look for wiring harness under seat to make sure its fastend to the seat framework.
Check to see if the jack is tight,(under pass seat) some have had mounting bolt backed off, and then caused a rattle too.
Let us all know what you found when you`ve fixed it...good luck to ya
You might be able to bullshit your way to the top, BUT, it wont keep you there
Never believe what you hear, and only half of what you see
Old 06-24-2010, 12:42 AM
Rep:2657
by the way, there is a notice, i forget what it is called, the seat brackets ARE faulty
OH, its called a TSB, technical service bulletin
Old 07-07-2010, 12:31 AM
hey guys, I tilted the passenger seat back and the rattle stoped. I put the seat back up and got the sound again (with my kid in the back holding the seat belt), the passenger seat gets a pretty good vibration and starts the rattle when the seat is straight up, put it at a slight angle and the vibration stops. This is my only complaint so far, 1 month owner with 1k so far. LOVE THE TRUCK, hate the rattle.
