Old 04-18-2010, 02:13 AM
racer965 racer965 is offline
racer965 is on a distinguished road
Default Really Need Help About to GIVE UP 5.9l MAGNUM Ram 1500
Ok guys I bought this truck off my boss its a 1999 Ram 1500 with the 5.9 Magnum in it. Since the day I bought it the idle has been wierd, it will idle somewhat smoothly for a while and then get rough and then sometimes the truck will actually stall. Also whenever you hit the gas it seems to bog then start moving then bog over and over again sometimes followed up with a spark knock, it does this off and on its very wierd. Im getting 6.9 mpg!!!The thing that is really discouraging me is I changed the belly pan gasket and pan and its still doing it. The plugs, wires, cap, and rotor are also relatively new. I dunno where to go from here and have no clue what the problem could be. The only mods I have is a intake and lift. Is it possible for the tranny to be causing this??? Sorry for the long post. PLEASE HELP ME THANKS GUYS!!
Old 04-18-2010, 03:16 AM
Rep:4072
Man, unfortunately, I don't have an answer for ya' and hopefully someone will be along shortly that can lend some assistance, but I did a basic search and came up with some other threads on this topic that might help you in the meantime:
http://www.ramforumz.com/search.php?searchid=368641
Good luck!
Old 04-18-2010, 06:42 AM
Have you had the truck scanned for any codes ? Cleaning the throttle body (if not already done) could help with the idle quality . Another member on here has been complaining about the same issue . It could be low fuel pressure , bad map sensor , tps etc... Check for codes first and get back to us . It would be great if you could also go to the newbie section and introduce yourself . Also complete your profile in the User Cp at the top of the screen . It shows us what you have when posting a comment or a question .
Old 04-18-2010, 08:38 AM
Rep:1890
I'm liking the MAP sensor idea. If you have access to a scan tool that will give you a data stream, hook up a vacuum gauge to manifold vacuum and compare the readings from the scan tool to the vacuum gauge. At any given RPM the MAP voltages should be relatively stable and not jumping around.
Old 04-18-2010, 12:41 PM
Default Scan
I did have it scanned before I did the plenum gasket it was a miss fire on no. 8 cylinder, and bank 1 rich condition. I cleaned the throttle body whenever it was off th truck. IM gonna scan the truck again now since the check engine light is still on.
Old 04-18-2010, 11:02 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
i hope you get it solved
Old 05-03-2010, 10:42 PM
I realized today that it seems like the truck only acts up whenever im below a 1/4 tank of gas?? Does this help u guys out with my problem im really getting frustrated with it. Im about to swap in an old engine to get away from all the bullshit.
Thanks,
Drew
Old 05-04-2010, 09:54 AM
Rep:1890
Check the fuel pressure and volume when the level is low and it's acting up. You could have trash in the tank that's causing a problem.
Old 05-04-2010, 10:41 PM
I lied i guess lol it does do it when the tank is fool too??? The code that it threw was p0132 O2 sensor high volts?? What should I check first could my cat be clogged due to the plenum leak???
Old 05-05-2010, 09:29 AM
Rep:1890
You either have a bad sensor, short to power on the signal wire or bad PCM.
