United Radio
Old 05-05-2010, 10:45 AM
Fredniner's Avatar
Fredniner Fredniner is offline
Vehicle: 2002 Ram Quadcab
Rep:30
Fredniner is on a distinguished road
Brother had the same problem with his 99, try changing the o2 sensor and if that doesn't do it, check for a short, the wires tend to get a little burnt where they are located. My brother ended up puting a new cat on as well.
Hope this helps!
Old 05-06-2010, 01:03 AM
macbrewer84 macbrewer84 is offline
Vehicle: 1997 Dodge Ram 1500
Color: Many
macbrewer84 is on a distinguished road
i was having a similar problem, my vapor canister had disintegrated, and the charcoal inside of canister got sucked up the vacuum lines and into the canister purge solenoid. i think that this was messing up the vacuum pressure and making the truck run like poo. i was also getting codes for all-cylinder misfires.
Old 05-09-2010, 02:45 AM
racer965 racer965 is offline
racer965 is on a distinguished road
I ended up buying a 02 sensor off ebay for pretty cheap,put it in and now my truck runs better than ever thanks for the help guys. Should I change the downstream one as well, will it make my gas mileage even better???
Old 05-10-2010, 05:48 PM
Rep:1845
We generally recommend to change upstream and downstream at the same time but I can't say you'll see an economy increase by doing so.
Old 05-16-2010, 03:27 AM
Alright thank you everyone. Especially you remerson, your alot of help and I like seeing your responses in other post for other advice on issues. Thanks again.
