Old 04-18-2010, 12:54 PM
Dhunter Dhunter is offline
Dhunter is on a distinguished road
Smile What year of factory wheels will fit my 2003 Dodge 1500 quadcab?
Hey guys I have 2003 Dodge 1500 QuadCab with the Hemi and i bought the truck with 20inch wheels and 35/12.5 r20 Toyo Open Country Mt and want to go back to a stock wheel and tire what years of truck wheels will fit and what tires do you recommend? When sold from factory it had 275/60r20s can i switch to a 17inch rim without messing up the ratio's in the rearend?
Old 04-18-2010, 01:12 PM
Rep:1625
Welcome to the forum! Glad to have you here! Those Toyo's are nice tires, if you want to switch to a 17" rim, you should have no problems.
Old 04-18-2010, 02:00 PM
Wheel Specifications:
1994-1999 1500 2WD/4WD Aluminum Wheels
• Lug Pattern - 5 on 5.5", 1/2" bolt
• Rim Size - 16x7.0"
• Offset - +13.97mm
• Backspace - 5"
• Max Tire Size -
• 15x8.0 rims with 3.5" backspace will fit, but they stick out of the wheel wells.
Torque Spec
• 80-110 ft lbs (108-150 Nm) on 5 stud wheels
2000-2003 1500 2WD/4WD 17" Steel Wheels (Chrome or painted)
• Lug Pattern: 5 on 5 1/2
• Rim Size: 17x7"
• Fits 94 and up 1500 trucks
2000-2003 1500 2WD/4WD 17" Aluminum Wheels:
• Weight: 23.5 pounds
• Rim Size: 17x8"
• Actual width edge to edge: 9 1/16"
• Backspacing: 5 9/16".
• The space from the outside edge to the mounting surface (against the rotor) is 3 1/2".
• offset calculate: 1 1/32"
What tires you go with depends on whether or not you need some traction in mud or snow. If not, a highway tread tire (such as the Toyo A/T) would work fine.
You can get the PCM flashed by the dealer for a change in tire sizes, or use a programmer, but I am wondering whether or not it was ever done when the larger wheels and tires were put on.
You can check this by doing an odometer check. On a fairly level road, that has mile markers, set the cruise at 60 mph and have a stopwatch or watch with a second hand with you. Check to see if you cover the mile in exactly 60 seconds at 60 mph.
I suspect that, with the larger tires, you'll probably be reading around 62 or 63 mph to cover a mile in one minute.
Old 04-26-2010, 01:08 AM
olsarge's Avatar
olsarge olsarge is offline
Vehicle: 2003 Dodge ram 2wd quad cab
Color: champagne
Rep:35
olsarge is on a distinguished road
Would you consider the factory chrome 17" from a 2003 quad cab? I have these but want the 20's
Pioneer AVH-4000DVD/JL Audio 2 12W3V3, 1000.1/focal poly glass all around/JL e1200 4 channel/Thrush SI/SO- specter drop in
