Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 04-18-2010, 10:32 PM
charley charley is offline
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
charley is on a distinguished road
Default 97 2500 2 whl 5 spd cummins
tranny locked in 5th gear, took top off, no problem with shifter? tried to pry gear no luck. solution?
Old 09-30-2010, 05:41 PM
coolhand51 coolhand51 is offline
Trim Level: SLT with Leather
Color: Brown and Silver
coolhand51 is on a distinguished road
Cool Likely a Nut Jam
Hi - If the trans is stock, then a common problem was the nut holding 5th gear on coming loose / dropping in the trans.
Likely you need to drop the trans, make sure you have a jack as the nV4500 is a heavy beast...
You should be able to retrieve the nut, you may have to disassemble the trans to do so. Thinks broomsticks for dummy shafts.
A Jasper rebuild will run ~ 2500
Good Luck
Coolhand
