Stability control - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram Special Edition Models > Dodge Ram R/T
Old 04-20-2010, 10:15 PM
2010Ramowner 2010Ramowner is offline
Vehicle: 2010 Ram 4x2
Trim Level: R/T
Color: Blue
Rep:48
2010Ramowner is on a distinguished road
Default Stability control
The owners' manual I downloaded from the net says that briefly pressing the dash button that the stability feature would be partially disabled until about 45 mph. Above that the system would come on again. The manual further says that to permanently disable the system, press the same button but hold it for five or so seconds. The manual then says it will stay off and the words "system off" will display on the dash. However, all that pressing of the switch for even longer only displays the icon and must be pushed each time I start the truck.
Does anyone have the suggested system or is this a 'manual mistake'?
2010Ramowner
Old 04-20-2010, 10:33 PM
Rep:3347
I got nothin' sorry. We'll see if any other R/T guys can help ya out.
Old 04-20-2010, 10:41 PM
When you have it off (partially off) by holding the button until the icon appears, it will revert to the default once you have cycled the ignition to Off and back to On.
So yes, you will have to disable it each time you turn the truck On.
My SRT8 Chrysler does the same thing.
Old 04-21-2010, 06:40 PM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default Esp off
DOESENT THAT SUCK. SAME WITH MY RAM RT. THE VIDEO FROM THE MOPAR GUYS SAID OUR TRUCK COMES WITH A HIGHER STALL YET WHEN I HOLD THE BRAKE AND BRING UP THE RPMs A CODE FLASHED SINCE I WAS BREAK TORQUEING IT. I TOOK IT TO THE DEALER. THEY PUT A NEW BREAK SWITCH IN. I HOPE TO GET ON IT NOW. I DONT HAVE THE TRUCK RIGHT NOW SINCE IT GOT HIT AT THE DEALERSHIP. THERE FIXING THE SCRATCH IN THE SIDE OF IT. I JUST FINISHED MY ANGER MGT CLASSES. GOOD THING!!!!
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
