Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 04-21-2010, 09:23 AM
racquetballfreq racquetballfreq is offline
Vehicle: 2004 Dodge Ram 2500 Diesel
Color: Blue
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
racquetballfreq is on a distinguished road
Default Haul/Tow Button
Ok, I know there are not suppose to be any stupid questions, but here's one for you to laugh about:
When do you use this button? I know on other trucks that I have owned, I have found the same button, but it is to turn off you overdrive.
This button seems to do the same, but I don't think that you want to use it if you are towing over, say 40 mph.
Help!
Thanks!
Old 04-21-2010, 11:05 AM
nelsont509's Avatar
nelsont509 nelsont509 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn SLT
Color: Detonator Yellow
Rep:17
nelsont509 is on a distinguished road
Since you posted here... Welcome to the forum This site bulges with info and the Ram Owners to back it!!
As I see you own a soot burner, Lol, I believe the "button" changes the shift points (RPMS). I own a Hemi and with the Button active, it still uses OD when it can. Hope that helps a little!
Old 04-21-2010, 02:40 PM
Rep:1625
Welcome to the forum! We're glad to have you here!
Old 04-21-2010, 02:44 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Welcome to the forumZ! Lots of great people to help you whatever it may be!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 04-21-2010, 03:19 PM
You have two selections, Tow/Haul & OD Off, if you push the button once, then once again.
Tow/Haul mode is generally used for towing in hilly areas. The OD off is generally used around town, hauling or empty, to keep from lugging the engine when on surface streets.
If you are towing over flat ground, leave it in full OD. That will get you the best mileage.
There's a section in the Owner's Manual that explains the operation of the transmission with respects to these two settings.
Old 04-22-2010, 04:31 PM
cuda71's Avatar
cuda71 cuda71 is offline
Vehicle: 2008 Cummins Dodge Ram 2500
Color: Electric Blue
Rep:27
cuda71 is on a distinguished road
And if you get a 6.7L diesel it also uses the jake brake more agressively to help keep your load under control when descending instead of wearing out your brakes.
Old 04-22-2010, 11:26 PM
I push the skinny pedal
Rep:3277
In the case of the cummins, it holds the gears longer, should downshift sooner under load, and it disables the O/D gears. I use mine when I'm hauling through hills/mountains to keep the RPMs up and to downshift on the downhill sections.
Kurtis
Old 05-23-2010, 09:15 AM
jrhopy jrhopy is offline
Vehicle: 2010 Ram 2500
Color: Tan
jrhopy is on a distinguished road
Send a message via Yahoo to jrhopy
I have a 2010 Ram 2500 diesel. When I asked the same question, I was told that it was to be used when you are towing or hauling in hilly areas. it reduces the gear selection from 6 to 3 so that the truck is not constantly "hunting" for the right gear. On my first pull, I took my 5th wheel from Houston to the Texas Hill Country and could tell the difference when I engaged it...John
Old 05-23-2010, 09:24 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Welcome to the RAMz, this is the place to be for help with your RAM. Enjoy the forum.
Old 05-26-2010, 07:39 PM
cuda71's Avatar
Rep:27
I don't know about reducing the gear selection from 6 to 3 it seems like when I use my 08 it uses more than three gears in tow/haul mode
