Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
tonneaucovered.com
Old 04-21-2010, 09:43 AM
bvibum bvibum is offline
Vehicle: 2004 Ram 2500 5.9l Cummins
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
bvibum is on a distinguished road
Default vent selector switch screwed up
The rotory knob that selects where you want the air to go is ineffective, the air blows from every duct regardless of selection. I have an 2004, and unsure if this is a vacuum controlled switch and have something going on there, or this is an electrical ( replace the box) type problem.
Please help!
Old 04-21-2010, 09:53 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Sorry I don't have an answer for you but wanted to welcome you to the site. Don't forget to head on over to the newbie checking and introduce yourself
Old 04-21-2010, 09:56 AM
Rep:1625
Sorry, I'm no help either.... but welcome to the forum, we're glad to have you here.
Old 05-04-2010, 07:26 PM
MikeHTally's Avatar
MikeHTally MikeHTally is offline
Vehicle: 2003 Dodge Ram QCSB
Rep:21
MikeHTally is on a distinguished road
Sounds like the infamous "blend door". When it malfunctions, you can't change the airflow. Fairly common (and expensive) failure.
2003 QCSB Ram, 2006 Chrysler 300C, 2008 1/2 Mazda Speed 3.
Some tweaked more than others.
Old 05-04-2010, 08:10 PM
I push the skinny pedal
Rep:3308
Welcome to the Z! Sadly, sounds there is a blend door failure most likely, it's annoying to change as you have to dismantle the whole dash to get to the problem. Chrysler has a repair kit specifically for this problem.
Kurtis
Old 05-05-2010, 08:25 PM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
is it any bit of fun as the 5-1/2 hours that it is the recirculation door replacement
Old 05-06-2010, 03:40 AM
olsarge's Avatar
olsarge olsarge is offline
Vehicle: 2003 Dodge ram 2wd quad cab
Color: champagne
Rep:35
olsarge is on a distinguished road
could this be the same problem that I'm having my ac blows cold but no matter where I turn myselector low, med, high it all comes out the same super low and makes me sweat like a pig in june... plz help I checked the ac levels with my gauges and it all works great but inside it blows low and barely at all, but the air is cole...Also I know the blower seems to be working bc I can hear it kick on all the way from low to high changing its speeds..
plz help I live in texas and its HOT as Hockey sticks
Pioneer AVH-4000DVD/JL Audio 2 12W3V3, 1000.1/focal poly glass all around/JL e1200 4 channel/Thrush SI/SO- specter drop in
Old 05-17-2010, 06:35 PM
MikeHTally's Avatar
Rep:21
