Old 04-21-2010, 03:25 PM
lrn2ski's Avatar
lrn2ski lrn2ski is offline
Vehicle: 2007 Ram 1500 4x4
Trim Level: Bighorn
Rep:81
lrn2ski will become famous soon enough
Default gascap warning (couldn't find topic with search)
So yesterday, I start up my '07 Hemi 1500 and as I am backing out of the driveway I hear a bell. I look at the dash and see the word "gascap" in the display. The tank is about half full, I stop, shut off the engine, and make sure the cap is securely tightened. (it is) I remove it, retighten it, and start the engine again. "ding". . . "gascap" appears once again. I ignore it. It comes on every time I start the truck, and now the check engine light comes on too.
What do I start looking for?
'07 RAM 1500 Bighorn 4x4 QC HEMI. 2.5" Daystar lift, 305 70x17 Terra Grapplers, Dick Cepek DC-2's
Old 04-21-2010, 04:25 PM
You need to replace the cap. The seal at the cap is leaking.
Old 04-21-2010, 04:37 PM
allencoon's Avatar
allencoon allencoon is offline
Vehicle: 1993 Dodge Ramcharger
Trim Level: LE
allencoon is on a distinguished road
Down load the computer code.
Ramcharger 1993 LE / 6" lift / Lund visor / 5.2 Mag./ Metallic Silver / THAT'S WHY I'M HERE!
Old 04-21-2010, 05:01 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Is this a short cut for some of the evap emission codes?
Old 04-21-2010, 05:24 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Post
Had this happen on my Dakota. I switched to a locking gascap that was not sealing properly. After about 1/2 hour the check engine light came on (and stayed on). When I got home I put the factory one back on and it took about 1/2 hour of driving before the check engine light went out. To be 100% sure you should see if you can pull the DTC codes, see what the computer posted.
Old 04-21-2010, 05:44 PM
Rep:1845
Check out page 387 of your owners manul for info on the gas cap message and instructions on how to turn it off.
Old 04-21-2010, 10:17 PM
lrn2ski's Avatar
Trim Level: Bighorn
Rep:81
Thanks for the help. How do I go about pulling computer codes. . . without visiting my friendly Dodge service department.
. . . I'll check my owners manual as suggested.
Old 04-22-2010, 01:13 AM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
most part stores will pull codes for free.
Kurtis
Old 04-22-2010, 01:55 PM
Color: Garnet red
Rep:202
You can also do the key dance, key off, then on 3 times. Codes should show in the odometer window.
