Tire Size - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 04-21-2010, 04:18 PM
01RAMguy's Avatar
01RAMguy 01RAMguy is offline
Vehicle: 2001 Ram 1500 club 4x4 5.9 v8
01RAMguy is on a distinguished road
Question Tire Size
I previsouly posted about what size tire that I can run on my truck. I know the max size is a 33in tire but I need to know what the max size that is that I can put on the stock rim. I was hoping to run 295/75/R16 nitto terra grapplers, will these fit the stock rims?
Old 04-21-2010, 08:25 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
I should be able to help you out if i knew the width of your stock wheel?
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 04-21-2010, 09:59 PM
01RAMguy's Avatar
That's the problem I don't know the width of the wheel. It is the stock 16in rim but that is about all I know.
Old 04-21-2010, 10:13 PM
Ruffian11's Avatar
Rep:140
So i found the your rim is an 8" wide rim....running that size tire should be a problem at all, im running a 325 on a 9" wide wheel and have seemed to have any problems!
A little wider would be a bit better...but you shouldnt have a problem with a 295 tire!
Hope this helps
Old 04-21-2010, 11:37 PM
01RAMguy's Avatar
Thanks alot I really appreciate it.
