Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 04-21-2010, 09:02 PM
03ramit1's Avatar
03ramit1 03ramit1 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Silver and Dirt
Rep:20
03ramit1 is on a distinguished road
Default is everyone scared of a little nitrous?
why are there no posts in the nitrous section? nitrous is fun you guys need to try it sometime. and when used safely it poses no threats to your motor.
Had a 12 second truck, now its a giant paper weight as of 1 may 10.
Old 04-21-2010, 10:03 PM
I push the skinny pedal
Rep:3277
Just haven't gotten around to a nitrous system yet... other mods are taking a higher priority...for now
Kurtis
Old 04-21-2010, 10:05 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
i dont want to void anything and in some places if the police catch you with you can get in trouble
Old 04-21-2010, 10:06 PM
iRESQu iRESQu is offline
Rep:2217
I am still learning but in my scenerio, I was told there is a propane system I need? (6.7l Cummins Diesel). Although, honestly I am not ready for that yet. But definitely want to know all the goods about it!
Old 04-22-2010, 11:27 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
..Chris (03ramit1) likes the spray...
Old 04-22-2010, 11:30 AM
ScatPak07's Avatar
Rep:970
I was thinking of getting some spray for my truck but if you get caught with it hooked up here they will impound the vehicle or even crush it. I dont want to loose my truck haha so I will wait on that mod.
Old 04-22-2010, 11:43 AM
Rep:1877
A lot of people are afraid of giggle gas because of the horror stories of catastrophic engine failure caused by someone that didn't know how to properly tune an engine to run on the bottle. I can't tell you how many people I've seen try to add fuel instead of pulling off nitrous when their plugs show a lean burn or try to run way too much total advance ignition timing. I even saw one fool blow his intake clean off because he tried to "purge" the air out of the nitrous line by revving the engine up in neutral and hitting the button. Purge solenoids are much cheaper than aluminum intakes.
Old 04-22-2010, 11:00 PM
Rep:3277
LMAO, wow, that would've been interesting to see.
Kurtis
Old 04-22-2010, 11:52 PM
03ramit1's Avatar
Rep:20
I myself have fallen victom to the too much nitrous addiction. i attempted to spray a 350 shot in a stock bottom end 350 once many years ago. have you ever seen heads that are still attached to the block but you can move them arround on the head bolts? I have i was able to lift the head high enough off the block to remove the gaskets and i never had to loosen a bolt. that was a fun ride while it lasted though.
Lesson learned: 350 shot of nitrous is too much for a stock 70's fuel pump to handle.
things have changed a little since then, motors have become alot more expensive to replace and having other responsabilitys such as family tend to limit the stupidity but hey it was fun at the time.
on a side note a safe nitrous set up can be run successfully for many many passes. i personally saw a 5.7 hemi motor that was taken apart because it hydrolocked and broke a rod. other than the trashed cylinder the motor looked brand new. it had close to 200 bottles of nitrous though it, and aprox 50,000 hard miles of off roading, drag and sand racing. and would probably have gone another 100,000 miles easy.
Old 04-23-2010, 12:49 AM
Rep:3277
What kind of set up do you have 03? I really don't know that much about it, aside from different NO2/fuel nozzle sizes, TBS porting, and needing a bottle warmer. I'd probably want a purge as well, but what all else do you need? specific regulator or is the open bottle enough with the nozzles, what diameter line, do you need a moisture trap? When active, is it continous injection or just a one time thing? Can you run water/methanol AND nitrous, or is that just for diesels, to keep the EGTs down.
I've toyed with the idea, but just wonder about the practicality with dealing with the Alberta winters and maintenance on the system.
Kurtis
