Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 04-27-2010, 12:21 AM
I push the skinny pedal
Rep:3277
Wow, I can only imagine what you'd say if you 'had more time'
Thanks a whole bunch man. I knew about the chemical interactions as I took aerospace engineering, however, putting theory into practical application is always the hard part. I appreciate the tips on the 'need' equipment, I'm an industrial safety officer now... gotta be safe when I speed I asked about water/meth as I'm a diesel guy at heart and W/M injection is a must for a high HP cummins motor and wondered if it carried over to manage EGTs.
I wouldn't run the system in winter, for the given reasons, but just wonder what kind of contraction I could get on the lines if I did leave them hooked up. I'd probably just leave it disconnected and capped. But in the summer they'd be hooked up, just so I could use it 'for passing' as I don't get much track time. I'd probably be running a 75-100 shot, and is it possible/or a good idea to have a duration limiter valve on the line so it only runs for a certain amount of time then auto shuts off? or is it just better to push the button to switch off?
Kurtis
Old 04-30-2010, 11:25 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
so i think i got this you need a window switch. bottle heater guage for the bottle the pressure i think that is it
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 05-01-2010, 03:10 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
guys wanna see Chris run? (03ramit1)..
Old 05-02-2010, 10:24 PM
Trim Level: st
Color: silver
Rep:68
12.9 WTF are his mods
Old 05-03-2010, 01:23 AM
03ramit1's Avatar
03ramit1 03ramit1 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Silver and Dirt
Rep:20
03ramit1 is on a distinguished road
thats my old truck. it had/has 150 shot of nitrous, ported and polished heads, spartan cam, 2800 stall tq converter, srt-10 axle (with 4.56 gears), hoosier slicks, BFI cold air intake, and long tube headers. and a bunch of other little things. that truck was rear ended on 5-1-10 it will be a total loss after the adjuster looks at it.
Had a 12 second truck, now its a giant paper weight as of 1 may 10.
Old 05-03-2010, 02:20 AM
chefred112's Avatar
Rep:656
that's one of Chris's 'slower' times..he was a lil quicker before his truck became a paperweight..
Old 05-03-2010, 02:18 PM
Trim Level: st
Color: silver
Rep:68
shit i should be close to them times i got sorta around the same mod except 100 shot
Old 05-03-2010, 02:22 PM
Rep:1885
I believe he said a 150 shot. You won't get too close to 12's without it.
Old 05-03-2010, 03:00 PM
chefred112's Avatar
Rep:656
there are a ton of factors involved in being 'close' to those times. I never assume that because a truck runs a certain time that I would too. If you did the EXACT identical mods as me (or Chris), then I say maybe. But i think you left out heads in your mod list (this is huge)... and you would prolly hafta get your custom tune from where Chris and me go to (Bob@SVS...not to take anything away from the other guys)... set your goals and start hitting the track...try going frequently enough to see how each new mod performs. And an important key is driver skill as well..no way a novice can drive my truck and get the same time's I get. So, two factors..mod combos and driver experience...
Old 05-03-2010, 03:04 PM
chefred112's Avatar
Rep:656
and also something to consider...if you look at the 5 quickest 1/4 mile na qc's... is it a coincidence that 4 outta the 5 are 05's and the fifth is an 06. It's been discussed how the 05 pcm's are the best ones to deal with when it comes to modding and custom tunes (with 03's, some 04's and 07's sittin on the opposite end with more difficulty to tune)
