Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 05-03-2010, 04:15 PM
03ramit1's Avatar
03ramit1 03ramit1 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Silver and Dirt
Rep:20
03ramit1 is on a distinguished road
you guys are missing a key factor too. You gotta have traction. A drag radial is not enough.you will need a full on race slick. I was cutting consistent 1.6 to 1.7 60 ft times. A 2.0 will not net you a 12 secnod pass. On a 100 shot I could manage to run a 13.2 on a 125 I could get12.9's and the 150 was 12.7's
Had a 12 second truck, now its a giant paper weight as of 1 may 10.
Old 05-03-2010, 04:26 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
..bingo..another part of the 'exact' mod combo.. bot chris and I both run slicks and caltacs..
Old 05-03-2010, 04:34 PM
Resident Technician
Rep:1909
If you're going to get that specific, then track prep becomes a huge issue as well. The best slicks in the world will struggle on a poorly or unprepped surface. Not to mention, track temp, air temp, baro pressure, humidity...all the things that figure into the density altitude equation.
Old 05-03-2010, 04:53 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
Originally Posted by Remerson228 View Post
I believe he said a 150 shot. You won't get too close to 12's without it.
nooo noo no i on spray when i get my rest of my part on 100 shot i know he on 150 but i should be sorta close
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 05-03-2010, 04:55 PM
Trim Level: st
Color: silver
Rep:68
there are a ton of factors involved in being 'close' to those times. I never assume that because a truck runs a certain time that I would too. If you did the EXACT identical mods as me (or Chris), then I say maybe. But i think you left out heads in your mod list (this is huge)... and you would prolly hafta get your custom tune from where Chris and me go to (Bob@SVS...not to take anything away from the other guys)... set your goals and start hitting the track...try going frequently enough to see how each new mod performs. And an important key is driver skill as well..no way a novice can drive my truck and get the same time's I get. So, two factors..mod combos and driver experience...
I totally agree with you i mean like 13.4 i know its far away i mean in the same are i talking about below a 13.5
Old 05-03-2010, 04:56 PM
Trim Level: st
Color: silver
Rep:68
and also something to consider...if you look at the 5 quickest 1/4 mile na qc's... is it a coincidence that 4 outta the 5 are 05's and the fifth is an 06. It's been discussed how the 05 pcm's are the best ones to deal with when it comes to modding and custom tunes (with 03's, some 04's and 07's sittin on the opposite end with more difficulty to tune)
yes i been reading alot here and dodgefourms learned alot from everyone about mods still NO WAY close to getting done like you guys are (i so jelous) but i be that first 07 or maby not to hit 13.5 lol i be super hapy
Old 05-03-2010, 04:59 PM
Trim Level: st
Color: silver
Rep:68
yes i know of that hmm but arent slick like easy to break stuff because of the grip they get. will the caltacs prevent that in a way.
yes track prep is huge i just saying like 13.5 like i said i be sooo happy from there i see what i do
Trim Level: st
Color: silver
Rep:68
what is the difference between
5.7L PREMIUM Big Valve Cylinder Heads and Sharadon Performance SP-2 5.7 Hemi Ported Cylinder Heads
the specs look the same
Old 05-03-2010, 05:09 PM
03ramit1's Avatar
Rep:20
now keep in mind in racing a 13.4-13.5 is not considered anything close to a 12.9 and definatly not close to a 12.7. close in the racing world will be about .1. your talking half a second or more, that is not considered close. yes slicks can brake things. thats because your only as strong as the weakest link and if the weakest link is the friction of the tire to the track that will give out first. yourun a slick and the bite it has no the track is better than the ujoint in the drive shaft the u joint will fail. i have a driveshaft (and u joints) that was custom built. i was told that if it fails under 1000 HP they will replace it and anything it takes out for free. with the SRT-10 rear end, (its a dana super60) it will hold up to a bunch of abuse. my weak link is the trans, so if anything was going to fail it would have been there. its not as simple as bolt on heads cam and nitrous and run fast. you gotta built the whole truck.
man i hope you can be the first on DFZ to run a 13.5 in your 07 but there are a bunch on another board that allready run that and faster.
Old 05-03-2010, 05:14 PM
Resident Technician
Rep:1909
True, especially when you consider that each .10 of a second is approximately one vehicle length. Being beaten by 5-6 lengths certainly isn't close.
