Old 04-21-2010, 11:00 PM
idleman's Avatar
idleman idleman is offline
Vehicle: 2005 Dodge Ram Quad Cab 4x4
idleman is on a distinguished road
Default Diff Fluid and Transfer Case
I have a 2005 Dodge Ram 4x4. The diff fluid and transfer case need to be changed. The dealer said it was time, but I cant afford the 450.00 to do it there. Question is, what kind of synthetic fluid goes in the diffs and what about the additive for the limited slip? Can I only buy that at a dealer? I was told that the 2005 model year has a bunch of choices and it can be found out by checking my VIN number.
Thanks
Old 04-21-2010, 11:23 PM
RamTech RamTech is online now
Rep:1884
75w-140 for the diffs with LSD additive for the rear and ATF+4 for the transfer case.
Old 04-23-2010, 05:18 PM
idleman's Avatar
Thanks Randy!!!
Old 04-25-2010, 01:19 PM
idleman's Avatar
Job Done! Didnt take long at all!! The guy at the dealer told me he thought the transfer case holds 4 litres , but I only got around 2 litres in. I found a listing of fluid capacities online and the dealer was wrong. Since I was feeling brave from my rear diff and transfer case jobs, I then pulled the throttle body off and cleaned it. Not a big deal. Truck is running great!
Next weekend is the front diff....
Old 04-25-2010, 01:25 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
That reminds me...i need to get on changing both my diff fluids, transfer case and transmission so im on some even ground with the truck!! i'll deff use that fluids! what about the front diff same fluid?
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 04-25-2010, 01:40 PM
I got mine done (all the cases) at the local oil change place...they had the limited slip additive.
Old 04-25-2010, 10:45 PM
idleman's Avatar
The front a rear diff fluid was the same--75w 120 Synthetic I think it was-except no Limited Slip additive for the front. I went to the dealer and they let me know which one to buy. I was advised the Rams can take a number of different fluids and the right one can be found out through your VIN.
Old 05-04-2010, 06:51 PM
MikeHTally's Avatar
MikeHTally MikeHTally is offline
Vehicle: 2003 Dodge Ram QCSB
Rep:21
MikeHTally is on a distinguished road
I did my diff two years ago. The PML cover added a bit of capacity. Total of four quarts plus the LSD additive. The clutch pack retainers were solidly in place, minimum of metal in the bottom of the pumpkin. I suspect it had been done before, but the PO wasn't aware of that specifically.
Very easy DIY, even the front diff included (from what I've read). Certainly easier and less messy than the tranny.
2003 QCSB Ram, 2006 Chrysler 300C, 2008 1/2 Mazda Speed 3.
Some tweaked more than others.
Old 05-13-2010, 06:29 PM
Valldar's Avatar
Valldar Valldar is offline
Vehicle: 2006 Ram 1500 - 5.7L HEMI 4x4
Rep:60
Valldar will become famous soon enough
Yep im looking to change both the diff fluid and the transfer case fluid as well. I'm not too experienced with cars, how hard would it be to change this stuff myself?
And I got an 06 5.7L 1500, what fluid types would I need for each? I would also like to put an LSD additive in the diffs.
Thanks!
ERIK
-=UPGRADES=- Focal K2 Component Speakers // 2x Boston G210-44 Subs // 2x JL 500/1 & 300/4 Amps // Rhino Lining Bed // Grillcraft Black Grille // 35w 5000k HID Fogs // 50w 6000k HID Heads // 0 Gauge Engine Wire Upgrade
