Place your Ad Here!
Old 04-22-2010, 12:07 PM
Hank Hank is offline
Hank is on a distinguished road
Default OBD II Problem
2010 ram laramie. I invertantly left the gas cap off and foundit about 2 hours later. All that time I never got a indicator light. I assume that is not normal. If it didn't pick that up what else is it not seeing?
Old 04-22-2010, 12:40 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
As I understand it, the diagnostic for the evap codes is run while key off, engine off, and can take a few hours. If you found it before the diagnostic was run, I think you should be OK. I would post how it works, but I found it on another forum. We've got a couple of Dodge techs here that should be able to explain it better. BTW- welcome to the forum!
Old 04-22-2010, 01:08 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Smile
If the computer detects a leak it takes some time before posting the code and turning on the MIL. Even if the MIL does come on once the leak is stopped the MIL will eventually go off. It just takes some time.
Not to worry..
sales@revelperformance.com
Old 04-22-2010, 02:03 PM
Resident Technician
Rep:1915
Some codes require a two trip failure to set a code and illuminate the MIL. After the first failure, the code should show up as pending.
Old 04-22-2010, 09:57 PM
Rep:3337
Yeah, what they said
