Old 04-22-2010, 11:21 PM
jstepy jstepy is offline
Vehicle: 2010 Ram 4x4
Rep:17
jstepy is on a distinguished road
Default 2nd Rainstorm... Dodge Still Not Waterproof!!!
Well the dealer said he fixed my water leak problem two weeks ago but after another storm last night I woke up to water dripping from the Driver Side A-Pillar again!
Long story short after another day at the dealers they realized the technician from the other week kinked my sunroof drain tube. They say it's all fixed but we will see next week as another storm comes into town.
Question... where is this drain tube? Others on the forum spoke of unclogging their drain tube etc? How can you check if it is clogged?
I might rethink a sunroof next vehicle!
Old 04-22-2010, 11:29 PM
UN4GTBL's Avatar
UN4GTBL UN4GTBL is offline
Vehicle: 2007 Dodge Caliber
Rep:41
UN4GTBL is on a distinguished road
After you get it back, why don't you get a hose and blast water at the sunroof to see if you can get it to leak again?
Might be less water getting in, but it would allow you to find out now, instead of later
2007 Dodge Caliber SXT - 1.8L I4 & 5-Speed Manual
2011 Dodge Grand Caravan SXT Plus - 3.6L V6 & 6-Speed Auto
Wanting a new Ram...
Old 04-22-2010, 11:32 PM
I push the skinny pedal
Rep:3322
I don't see why they didn't just spray the roof and see if they got anything leaking then and there. I know it's not 100%, but it's a lot better than waiting for something to happen. Hope they got it all sealed up.
Kurtis
Old 04-22-2010, 11:38 PM
Rep:17
Exactly... I don't think the dealer was to honest with me the first time. They said they water tested after the first go around and couldn't reproduce the leak after adjusting the door. I wonder if they even bothered checking.
This time they were able to reproduce the leak and saw the drain tube kinked... why they didn't see that first time I don't know...
But I'd really like to know how to check these drain tubes for future problems if anyone can explain where to look.
Thx
Old 04-23-2010, 07:55 AM
My ss got a ls's Avatar
My ss got a ls My ss got a ls is offline
Vehicle: 2010
Trim Level: laramie
My ss got a ls is on a distinguished road
The drain tube runs from the edge of the sun roof assembly to the bottom of the door a pilar it should be blue in color they need to make sure it is pushed on to the nipple completely
If you cant dodge it ram it
Old 04-23-2010, 08:30 AM
Hemi390's Avatar
Hemi390 Hemi390 is offline
Vehicle: 09 Ram 1500 Crew Cab 4x4 3.55
Rep:27
Hemi390 is on a distinguished road
Just thought I would share went thru carwash awhile back half way thru my little girl says dad its raining sure enough it was leaking on her head took it to dealer it was the third brakelight seal .
K&N drop in ,Debadged except tailgate ,1200 watt power inverter ,Bed rug ,LEER 800 tonneau
Old 04-23-2010, 08:35 AM
Resident Technician
Rep:1915
The process for reproducing a high pressure leak (storm, car wash, etc) is to hit it with a water hose under pressure. Low pressure leaks from mild rain are reproduced by using a hose with no nozzle and allowing it to flow over the suspected area.
Old 04-23-2010, 09:38 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:86
topgun will become famous soon enough
There is a RRT for the cab brakelight.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Husky X-Act Contour Floor Mats, Cooper AT3 285/70/R17's, Moroso Catch Can
