Old 04-23-2010, 09:54 AM
carnage's Avatar
carnage carnage is offline
Vehicle: 2001 Dodge Ram
Trim Level: 1500
Color: Red/Black
carnage is on a distinguished road
Default Oil Pressure Gauge Goin Crazy?
I have an 01 Dodge Ram 1500 5.9l 2wd, my oil pressure gauge is goin from 40 to 0 in a split second and jumps right back up. There is no knocking or noise and it runs just fine. I heard that the cause of the problem is the oil pressure switch so I am goin to replace it along with my oil later today and see if it helps any bit. I had my oil pump, crankshaft, and timing chain replace almost 2 years ago so I know thats all fine and I only put a couple thousand miles on since then. So does anybody have another suggestion while I'm at it?
PS the switch is located behind the intake manifold right beside the distributer on the passenger side if anybody has the same issue.
Old 04-23-2010, 10:08 AM
Rep:1909
Other causes include low oil level (which is very likely if you've never replaced the intake pan gasket), blocked pickup in the pan, or a bad pump. Since tow year old parts can go bad as easily as 10 year old parts, it would be wise to double check with a mechanical gauge since you'll already have the sending unit out.
Old 04-23-2010, 12:04 PM
carnage's Avatar
Trim Level: 1500
Color: Red/Black
By changing the oil, filter, and switch it should take care of those causes. My oil is a little low but its right close to the bottom of safe zone on dip stick, I think I will be good after i change everything if not I'll let yall know if the problem persists. also is trans fluid a good flush or shud i just get the real engine flush stuff, cuz i got a quart of trans fluid already just wandering if i could use that?
Old 04-23-2010, 12:11 PM
Rep:1909
Engine flushing is a BAD idea. Think about it - when you start breaking stuff loose inside your engine, where does it go? Straight into the oil pan and into the pickup screen. A co-worker recently told me of a flush done on a Tahoe with 40k miles on it with a Wynns system. Less than a month later the engine had to be replaced due to oil starvation.
Old 04-23-2010, 01:27 PM
carnage's Avatar
Trim Level: 1500
Color: Red/Black
I heard about that happening as well, so how do you get rid of the gunk with out it breaking off in chunks?
Old 04-23-2010, 01:36 PM
Rep:1909
Tear it down and clean it up. Otherwise, leave well enough alone.
Old 04-23-2010, 01:46 PM
carnage's Avatar
Trim Level: 1500
Color: Red/Black
yea screw that i'm building a 408 so might as well leave this block alone lol.
Old 04-23-2010, 04:39 PM
daveredneck's Avatar
daveredneck daveredneck is offline
Vehicle: 04 Ram 1500 4X4 5.7
Trim Level: slt quad cab
Color: silver
Rep:25
daveredneck is on a distinguished road
i had same problem with mi last ram 95 5.9 ,when drivin it home from just buying it(5 year old 70,000mile truck at the time )
new oil pressure switch sorted it had it for 6 years no more problem
Old 04-25-2010, 09:32 PM
Punisher's Avatar
Punisher Punisher is offline
Punisher is on a distinguished road
The 2000 RAM 5.2L I just bought once in a while when I am at a stop light the oil pressure guage drops to 0 in a split second. Soon as I hit the gas, or even sometimes if I put it in neutral it JUMPS back to normal. And my engine runs and sounds very strong, no ticking or other noises.
Hopefully we both just have flaky sending units.
Old 04-27-2010, 09:27 AM
carnage's Avatar
Trim Level: 1500
Color: Red/Black
I replaced the the oil pressure switch last friday and it got rid of the ever annoyin oil pressure drop! Punisher it sounds to me that you got the same issue and if so I'm tellin it fixed it. the part is only 20 bucks and easy to replace, go for it.
oil, oil pressure, oil pressure sensor
