Old 05-03-2010, 06:06 PM
Punisher's Avatar
Punisher Punisher is offline
Punisher is on a distinguished road
Originally Posted by carnage View Post
I replaced the the oil pressure switch last friday and it got rid of the ever annoyin oil pressure drop! Punisher it sounds to me that you got the same issue and if so I'm tellin it fixed it. the part is only 20 bucks and easy to replace, go for it.
That is great news man, glad to hear it was a cheap fix for you!
I hate to say it but I dont even know what this thing looks like or exactly where it is. I have a good aptitude for repairing things so if I can find a picture or diagram of where it is I'm sure I can handle it. Maybe I'll stop by Autozone on the way home and at least get the part.
Old 05-03-2010, 07:09 PM
carnage's Avatar
carnage carnage is offline
Vehicle: 2001 Dodge Ram
Trim Level: 1500
Color: Red/Black
carnage is on a distinguished road
its located behind the intake manifold on the passenger side, positioned vertically.
hard to see the connector on the end of it so you will have to feel for the clip to remove it, also don't forget the oil pressure switch socket which is like 5 bucks.
Old 05-03-2010, 07:11 PM
carnage's Avatar
Trim Level: 1500
Color: Red/Black
Old 05-04-2010, 06:49 PM
rscottj rscottj is offline
rscottj is on a distinguished road
so i have a 95 dodge ram 1500 4x4 5.9 and have the same oil issue i changed the oil sending unit, but it didnt fix it. is the oil presure switch something different or the same thing?
Old 05-04-2010, 06:54 PM
carnage's Avatar
Trim Level: 1500
Color: Red/Black
I believe its the same thing, idk did the sending unit look like that pic i posted cause that is the switch.
Old 05-05-2010, 02:24 AM
Punisher's Avatar
Bought the sending unit and socket today. But of course I forgot I didnt have the right ratchet for the socket.... Guess it's back to the store tomorrow.
Thanks for the info..
Old 05-05-2010, 02:54 PM
well thats what i changed but didnt cure the problem. maybe a bad new one
if it dosnt hurt the motor i can live with it, but when it does go
out i wont know.
Old 05-05-2010, 06:05 PM
rhysell07 rhysell07 is offline
Vehicle: 00 dodge ram 1500
rhysell07 is on a distinguished road
bet you its your oil pressure sending unit if thats not the problem check the wiring maybe its rotted and got some water in there or something otherwise it might be your gauge cluster
Old 05-31-2010, 12:58 PM
24vtd 24vtd is offline
Vehicle: 1999 ram 1500 reg. cab 4x4
24vtd is on a distinguished road
mine was the pressure switch also i also had a blown gasket on the plenum cover so i changed the switch when i had the intake off. Does it spark knock when you hammer it?
oil, oil pressure, oil pressure sensor
