Anti-Lock Brake Wiring Problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 04-23-2010, 10:53 AM
dkeith dkeith is offline
Vehicle: 2004 Dodge RAM 1500 4WD
dkeith is on a distinguished road
Angry Anti-Lock Brake Wiring Problem
After being parked for 2+ hours my 2004 RAM1500 started smoking from under the hood. On opening the hood the smoking wires burst into flames, which I extinguished easily, but the wires were glowing red. Wires were in a connector hooked to a block mounted behind the battery on the fender well that had hydraulic lines connected - one from the brake master cylinder. I disconnected the battery nad let things cool. could not dislodge the connector from the block. Touched the battery cable to the battery and got no spark, so I hooked it back up. The wires did not reheat. I tried to start the truck and it started fine. Seems OK...except the Anti-Lock Brake and the brake light are both on. Where do I go from here. Have had the lights come on before, but theywould go off after a while. Thanks.
Old 04-23-2010, 11:28 AM
Resident Technician
Rep:1915
First thing I'd do is try to locate the short that started the fire and determine why a fuse didnt blow. The burnt wiring should be replaced and the ABS scanned to see what codes are stored.
