Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 > Exhaust
Exhaust 5.9L Exhaust Discussion
Old 04-23-2010, 02:15 PM
StormTrippinFiVe9 StormTrippinFiVe9 is offline
Vehicle: 1999 Dodge Ram
Trim Level: Sport; Blue decals
Rep:17
StormTrippinFiVe9 is on a distinguished road
Send a message via AIM to StormTrippinFiVe9
Talking Exhaust Help!
Hey all,
In the next couple of weeks i plan on getting a new exhaust setup for my stock 99 ram 1500. It has a 5.9L v8 engine in it. I've been looking around to see what would be the best setup for the truck which would give me the best performance.
I would like to get a magnaflow CAT plus a magnaflow muffler(s) as well.
What my question is is that should i get an X-pipe, H-Pipe, or a Y-Pipe setup or just straight pipes? ive been told that a Y-pipe would be just fine but i just wanna make sure.
Any information on this would hep.
thanks a lot!
Old 04-23-2010, 02:34 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Right now I have a cat-back exhaust, I believe with a Y, but not sure. It has magnaflow tips on it and its pretty mean sounding. No muffler
Old 04-23-2010, 02:35 PM
Resident Technician
Rep:1909
I prefer true duals with siamesed pipes (pretty much the same as an X setup).
Old 04-23-2010, 04:38 PM
The Y pipe takes two pipes from the manifolds and puts them into one pipe. So if you are going to go with a dual setup, you won't use a Y pipe, you'll use an X pipe.
Old 04-23-2010, 05:21 PM
Rep:17
couldnt u just put a Y after the cat which would make it duals?
Old 04-23-2010, 05:29 PM
Resident Technician
Rep:1909
Yes, but it's not true duals. If all you want is the look of dual exhaust, that's fine.
Old 04-23-2010, 11:27 PM
I push the skinny pedal
Rep:3308
If you want the true duals then you want an X-pipe or to run duals straight out you can use an H-pipe just to equalize bank pressure.
Kurtis
Old 04-25-2010, 12:41 AM
Rep:17
yeah ive heard that the x pipe and h pipe gives you the best performance and i would really like to get an x pipe setup but some say i would have to get a custom fit cause its a really tight fit underneath. couldnt i just buy a regular x pipe from magnaflow or do i have to have one made?
Old 04-25-2010, 12:43 AM
ScatPak07's Avatar
Rep:970
If you want to make true duals then you will want to go with a X pipe. The Y pipe brings two pipes into one to the muffler. I would do X for true duals and then a Y if you want one mufler with two exits
