Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 05-11-2010, 09:22 AM
floodjp floodjp is offline
floodjp is on a distinguished road
The dealer did an alignment, cut rotors and balanced the tires. They never changed the pads because the pads were fairly new and the shaking was occurring with the original pads as well.
I never thought of going directly to Chrysler about this since I thought that the dealer could fix it. But it is documented at the dealer prior to the warranty expiration. Thanks Randy, I will try that before spending more money on the problem.
Old 05-17-2010, 03:02 PM
volcom54626's Avatar
volcom54626 volcom54626 is offline
Vehicle: 2006 Dodge ram QC
Color: Brilliant Crystal Black
Rep:17
volcom54626 is on a distinguished road
Well I replaced the rotors over the weekend just to see if that would help. No luck still does.
Old 06-01-2010, 12:58 AM
All4Traction All4Traction is offline
Vehicle: 2006 Ram 1500 5.7L
Color: Inferno Red Pearl
Rep:27
All4Traction is on a distinguished road
Any updates? I have an 06 slt 4x4 5.7L and Ive had the same brake wobble when hitting the brakes at highway speeds.
Its not the rotors, or pads, or shocks, or outer tierod ends, or alignment, or tires. I just had a safety inspection done and they found nothing.
I had a recall done for front hubs and bearings a couple years ago, it never made a difference. I wonder if they even changed the wheel bearings? or is this a rack and pinion problem?? Im troubleshooting the best I can.
I replaced all of the above items with brand new parts over the last couple years, nothing has made a difference.
06 Ram 1500 4x4
[IMG]http://i23.photobucket.com/albums/b380/All4Traction/DSC01858-1-1.jpg[/IMG]
Old 06-01-2010, 09:18 AM
Resident Technician
Rep:1909
Anyone bother to check the runout, thickness variation and variation from parallel on all rotors and what were the numbers?
Old 06-03-2010, 04:45 PM
sablefish's Avatar
sablefish sablefish is offline
Vehicle: 2013 ram sport
Trim Level: sport
Color: red
Rep:78
sablefish will become famous soon enough
I also have the same problem, I think this addresses the issue ( Dodge TSB 02-001-07 REV. A ) but not 100% sure. Has anyone had this done and fixed the problem? Thanks
Models: 2006 - 2007 (DR) Ram Truck (1500)
NOTE: This bulletin applies to 4x2 and 4x4 light duty (1500 model) vehicles built on or before November 27, 2006 (MDH 1127XX).
Overview:
This bulletin involves identifying the type of vehicle drift that may be present and implementing the appropriate repair procedures for the type of vehicle drift
Symptom/Condition:
The customer when braking may experience a vehicle drift to one side and/or a vehicle body shudder. This condition may be more noticeable when brakes are applied at speeds of 88 km/h (55 mph). The vehicle body shudder may exhibit itself as: steering wheel shake, brake pedal pulsation, or seat or floor vibration.
2013 ram sport, 8 speed. pace edwards full metal jack rabbit tonneau, bed slide 1500cg bedslide, husky weatherbeaters
Old 06-03-2010, 10:39 PM
Rep:27
Hmm, Ill have to take a look back and see what TSB they did on my truck. Looks like ill be talkin to a Dodge dealer soon.
Thanks for the post!!!
06 Ram 1500 4x4
Old 06-03-2010, 11:06 PM
MrsBuck's Avatar
MrsBuck MrsBuck is offline
Vehicle: 2007 Dodge Ram 1500
Color: Inferno Red
Rep:32
MrsBuck is on a distinguished road
I too have this issue......thought I needed new brakes, pads & the whole deal. Glad to know it wasn't just me. Can't wait to solve this.
Old 07-21-2010, 11:58 AM
gmag69's Avatar
gmag69 gmag69 is offline
Vehicle: 2007 Dodge ram quad cab
Trim Level: Big Horn edition
Rep:18
gmag69 is on a distinguished road
I have this same problem also. My truck shakes so bad around 55mph when you put the brakes on it feels like the front end is going to come apart. I'll be watching this to see what happens. I'd like to get it fixed.
Old 07-21-2010, 02:23 PM
sablefish's Avatar
Trim Level: sport
Color: red
Rep:78
I put new tires and rims on my truck and the problem went away. It looks like my right rear tire had a broken belt in it ( there was a slight bulge on the inside of the tire) I found out that broken belts are common on the goodyear tires and can cause this problem
Old 07-21-2010, 08:16 PM
mattg1500's Avatar
mattg1500 mattg1500 is offline
Vehicle: 2005 Dodge Ram QC
Rep:22
mattg1500 is on a distinguished road
My father inlaw has a dodge dealer in NJ and me and my dad were having this problem. with my dads dakota the truck needed a balljoint(35k mi) and the rotors need to be turned on the vehicle! there is an issue with the hubs. My 05 ram needed new wheel bearings(50k) and rotors turned on truck. I replaced the hubs since and alls good.
