Old 04-24-2010, 03:39 AM
Iceburg Iceburg is offline
Iceburg is on a distinguished road
Default 95 Dodge Ram 1500 Fuel gauge not working?
My trucks fuel gauge isn't working. What do I need to do to fix this? would it be expensive to just have a mechanic fix it? I rather fix it myself if its something simple. Can you guys help me out please?
Old 04-24-2010, 07:19 AM
Rep:1909
Repair cost will depend on what the problem is. It could be the sending unit in the tank, the instrument cluster, the wiring...
Old 04-24-2010, 08:14 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Randy should be able to help you, but I wanted to welcome you to the site. Looks like he is needing some more info from you. What have you tried/tested?
Old 04-24-2010, 03:18 PM
Rep:1625
Just wanted to welcome you to the forum. We're glad to have you here!
Old 04-24-2010, 06:54 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Welcome to the forum!
Old 06-21-2011, 06:57 PM
pigman pigman is offline
pigman is on a distinguished road
Hello, how are you, I have problems with my fuel gauge on my Ram 1500 1994, some one have the schematic??
Best Regards,
Old 06-21-2011, 07:43 PM
wylie wylie is offline
Vehicle: 2011 Dodge Laramie 1500 CC
Color: Blue
Rep:55
wylie will become famous soon enough
Default fuel guage
iceberg and pigman,,,,does your fuel gauge ever work,,,like go up and back down. I had one that worked when it wanted to. I pulled the dash and found a loose wire on the back of the printed circuit board at the fuel gauge. It is connected on a stud with a tinnerman nut. I tightened it up and trouble gone. After I put the dash back I summised that if I had known what to look for I could have done that looking up with a flashlight from the floorboard. You might try if you want. Good luck.
Old 07-29-2011, 06:15 PM
shak01 shak01 is offline
Vehicle: 1996 Dodge Ram 1500
Color: Emerald Green
shak01 is on a distinguished road
If this is a gasser...9 times out of 10 it is the sending unit attached to the fuel pump (sold as a unit) in the tank. If your fuel gauge reads full when you fill it up and then goes down after a 50-100 miles and then starts floating up (when you hit the brakes) and down (when you stop) then it most likely is the float assembly. The pivot point bolt, contacts, and float arm assembly wear out prematurely as far as I am concerned! So...you have to buy a new complete pump assembly, drop the tank or lift the bed (your choice) and replace the fuel pump unit. Once you get it out...you'll see the problem...now on to the price! Dealer fix $500-750, DIY $150-200, crafty old man...one small spring, one small SS bolt and nut 10 cents
Footnote: If you go to the trouble of getting at the in-tank fuel pump/sender unit and the pump has been in there for 75K+ why would you go with the 10 cent solution? Answer: I'm retired and I have Time!. Don't forget to change the pump filter and locking nut O-ring gasket...anything else...hmmm...clean all the electrical connectors...I don't know...there's probably a dozen other things to do when you're that far in!
Schematic
Kevin Sharpe shak@att.net
Old 11-30-2011, 07:37 PM
Joe1500's Avatar
Joe1500 Joe1500 is offline
Vehicle: 1998 Dodge Ram 1500
Color: Red/Silver
Joe1500 is on a distinguished road
Default Random fuel gauge failure.
Hello.
I think I have a similar problem like the one wylie had (it shows the fuel you have, then drop to zero, bleeps a couple of times and go back, randomly, but more often from mid tank down)
Maybe you can tell me more about that loose cable. I removed the panel down the steering wheel, but no idea where it is.
Old 11-30-2011, 08:02 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I personally have done it (Sending unit) on a few Dodges. I find it far far easier to lift the bed than to contend with the straps, dropping the tank, lifting the tank etc...
If you're a newbie at it it also lessens the risk of breaking the plastic inlets and/or line connections. Six bolts and the license plate insert screws. Three nuts in the fuel door, unplug the tail lights, and one other person.
Each guy grabs it by the wheel well, lift it, and slide it back. Takes about a 1/2 hr.
