Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 04-25-2010, 11:57 PM
TASSY5 TASSY5 is offline
TASSY5 is on a distinguished road
Default right front wheel bearing went out
drove through some water the other day on some flooded streets and it must have washed out the bearing, Has this happened to anyone.
I also noticed my 06 Hemi is having sime suspention groaning any idea what to do about that?
Old 04-26-2010, 02:47 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
I've never had that happen to me in all the years that I've been driving. I've driven through the thunderstorms of the Prairie Provinces, the salt-ridden streets of Ontario/Quebec and the pothole layden roads of the Maritimes and I never experienced that. Bearings are a wear and tear item so it would've been starting to fail for quite some time.
Regardless, it's time to replace the bearings and I'd recommend replacing the entire hub assembly.
Old 04-26-2010, 08:15 AM
Resident Technician
Rep:1909
That seems like a pretty unlikely scenerio. Chances are it was nearly gone anyway.
Old 04-26-2010, 09:20 AM
I agree ^^^ with that. How many miles on your truck?
The "groaning" could be almost anything, including a shock, a bushing, a spring spacer or that bearing.
Old 04-27-2010, 12:05 AM
It's a sealed bearing . I can't see that happening . Are you sure you have a bearing noise ?
