Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 04-27-2010, 11:24 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Default Headlight and Third Brakelight Removal?
Are there any how too's out there on how to get them out?
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 04-27-2010, 11:33 AM
Rep:1890
For the headlight - http://www.ramforumz.com/showthread.php?t=45817
NOTE: The Center High Mounted Stop Lamp (CHMSL) for this vehicle may incorporate two integral cargo lamps. The center bulb is the CHMSL bulb and illuminates through a red lens, while the two outboard bulbs are for the cargo lamps and illuminate through clear lenses.
<A xmlns="http://www.w3.org/1999/xhtml"> 1.Disconnect and isolate the battery negative cable.2.Remove the two screws (1) that secure the Center High Mounted Stop Lamp (CHMSL) (3) to the rear roof header panel.3.Pull the CHMSL away from the opening in the roof header far enough to access and disconnect the headliner wire harness connector (4) from the pigtail connector on the back of the lamp housing.4.Remove the CHMSL from the roof header.
Old 04-27-2010, 11:47 AM
RamTex's Avatar
Color: Stone White
Rep:366
word! thankyou!
Old 05-09-2010, 04:44 PM
RamTex's Avatar
Color: Stone White
Rep:366
Is there a certain way to remove the third brake light cause its not coming off... I dont want to force it off for fear of breaking it. I mean i remove the screws and it slightly comes off about half an inch when i pull on it. Should i try to pry it off. Or am i just not doing something right to get it off any info would be great.
Old 05-09-2010, 05:02 PM
I push the skinny pedal
Rep:3277
You may be hooking the harness on the inside lip. Get a flat blade under there to lift up the harness.
Kurtis
Old 05-09-2010, 07:41 PM
RamTex's Avatar
Color: Stone White
Rep:366
got it off it just needed a little persuasion.
Old 05-09-2010, 10:01 PM
Rep:3277
good to hear.
Kurtis
Old 05-09-2010, 10:03 PM
ScatPak07's Avatar
Rep:970
Well I guess this is taken care of haha
